knock noise in front end
When driving over small bumps I get a knock noise in the front end more on the passenger side. I took it to tire kingdom they could not find anything but, there is definitely noise.
Makes me think about strut mounts.
I assume they would have checked the tie rod ends, so if they are good, the strut mounts would be my guess.
Don't know if you've been running lowering springs on the stock shocks, but this can make them fail early.
How many miles are on your car?
Also this may sound silly but if any work has been down recently on the front end, check to make sure the nuts and bolts are tight. I know if the top but on the strut assembly is a little loose it will allow enough play up and down to make a knocking noise over bumps.
can't burn rubber
I have 07 mustang gt with 76000 miles on it 373 rear end k&n 69 Cai and flow masters super 40s. When I floor it, I can't burn rubber. Car runs really strong through all gears. Any thoughts. Rear tires are 275 40 20
Diode Dynamics
Jun 12, 2018 03:26 PM
RRRoamer
Jan 19, 2017 05:27 PM
awoychosky123
'10-14 Exterior Modifications
Aug 18, 2015 08:30 AM
Mackitude
Aug 17, 2015 04:14 PM
