Install Tips Needed
Old Nov 10, 2005 | 08:19 PM
gregbe1's Avatar
Thumbs up
Just recieved the MUSTANG door sill plate decals, from bob white decals,
anybody have any Install tips they can pass along other then the supplied
info that came with the decals.
so far I have picked up...keep your fingers wet with soapy water so they dont stick to your hands.
Thanks !
Old Nov 11, 2005 | 11:05 AM
Duckman's Avatar
Also it helps to get a spray bottle with a drop or two of dishsoap in it. Spray the door sill before applying the decals. This will allow you to slide them slightly so they are exactly in the spot you want. Then when you press them down the excess water will squeze out. This sure help on my install.
Chuck
Old Nov 12, 2005 | 02:14 PM
Big Poppa's Avatar
I cleaned the door sill with alcohol first but aside from that did exactly as you did Duckman and they came out great.
Old Nov 17, 2005 | 10:08 PM
StangNut's Avatar
I bought a cheap set and they actually went on better dry, but that was because they weren't a perfect fit.
Old Nov 18, 2005 | 04:47 PM
S197 GT's Avatar
3rd Times A Charm
I clean the door sills and soaked the letters inthe soapy water. This is such an easy install!
Jim74656
May 1, 2023 02:15 AM
Ecostang
Nov 3, 2022 08:50 PM
MRGTX
2012-2013 BOSS 302
12
Aug 7, 2015 08:29 AM
ClayP
Aug 3, 2015 09:00 PM
