I conqured it!!!!
I conqured it!!!!
I've had a rattle in my driver's side door panel/window area. I finally got a chance to take it to the dealer and they fixed it in an hour
Both upper window regulators were loose and started to back off of the threads.
If anyone is experiencing a similar ticking/rattle with the window up and it sounds more pronounced when the window is cracked or down, this may be your issue as well just as a heads up
Quite a few people are having this with their verts. Get to the dealer and tell them that it makes this sound when the window is closed, and it is even more pronounced with when partially open. Every little bump or imperfection sent me through the wall with this thing.
Good to know, mine does rattle but I don't hear usually because my music is blarring.
How do I go about getting this fixed though? Just call my dealer and say hey my car has rattle near the front of the "blah blah"?
I did. I also told them that I had the door panel TSB done and they wanted to make sure that nothing was loose from that excursion. Just be sure to point out that you notice it from the upper door panel area.
Thats what I did anyway.
