Help me choose my Clutch----which brand?
Old Jun 28, 2010 | 08:51 PM
UltraKla$$ic's Avatar
Replacing the clutch, pressure plate, and throw out bearing in my Mustang.
Which brand offers the BEST clutch?
Centerforce
Spec
McCleod
Fidanza
Please suggest.
Old Jun 28, 2010 | 11:06 PM
Antigini-GT/CS's Avatar
Founding MOTM
Committee Member
Depends on what you want out of the clutch and what type of clutch you intend on getting.
Old Jun 29, 2010 | 06:56 AM
By "best" I meant closest to OEM feel. I don't want a heavy clutch as this is my daily driver. I want one that is quiet, works well with the OEM slave cylinder for years, grabs well, easy actuation, and has some potential for a little more power later on.
I was leaning towards the Centerforce before I posted, I just need some more input from those that have used the various offerings.
Old Jun 30, 2010 | 01:47 PM
eighty6gt's Avatar
Clutchmasters twin disc, give them a call!
Old Jun 30, 2010 | 05:07 PM
Bullitt995's Avatar
Don't get a twin disc unless you make a bunch of power. I had a centerforce for a long time that served me well for about 30,000 miles of really, really terrible abuse. I'd go with that or a SPEC 3+ which I've heard mostly good stuff about.
Old Jun 30, 2010 | 05:27 PM
tom281's Avatar
Spec 3+.
Old Jul 1, 2010 | 07:22 AM
No problems with my Centerforce DF. Pedal feels normal to me, but others that tried it tell me that it's heavier than stock, but not by much.
Old Jul 1, 2010 | 01:37 PM
TKEUofM's Avatar
I actually prefer a little heavier clutch, makes you feel like your "driving" more. I test drove the new 5.0 and loved the power, but actually hated the clutch because it was too light.
Old Jul 3, 2010 | 05:55 PM
shanec's Avatar
I like my Centerforce DFX, but it does not feel stock. Pedal is firm, but not real stiff - not enough to ever make your leg tired. I prefer this.
I have read from many people that say the McLeod twin disc (RSX? forget what its called) feels like stock. A twin disc engages more slowly than a puck style like a centerforce. This makes it fell more like stock.
I'd say avoid Spec like the plague. Some like the 2's, some hate. Some like the 2+, some hate. Same with the 3. I say why gamble.
I think you cannot go wrong with Centerforce or McLeod. The Centerforce is going to be quite a bit cheaper though. I guess a twin disc design (McLeod) is expensive.
If you get a Centerforce, I suggest also doing the FRPP steel clutch line upgrade. The stock plastic one can balloon and crack under the extra hydraulic pressure that a puck style (Centerforce) clutch will put on it. However, with a McLeod (twin disc), this is not a problem.
Old Jul 3, 2010 | 05:57 PM
shanec's Avatar
Exactly the way I feel. The stock clutch on my GT felt just as limp as the one on my 1st car ever - a 1986 Toyota Corolla. Car just feels stronger with a manly clutch that is stiffer to push in, and more importantly engages faster. Car just wants to jump forward (but I must also say it is still not a problem to feather the clutch around in a parking lot).
Old Jul 4, 2010 | 12:57 PM
Well after much deliberation and input from other forums as well, I went back with a stock clutch. It feels so limp! WTF It needs some clutch Viagra!! It does the job, but I wish I would have went with an aftermarket offering, however, some were saying the aftermarket clutches are hard on the OEM slave cylinder. I certainly didn't want to be back under the car anytime soon changing parts again.
Old Jul 10, 2010 | 01:55 PM
RRRoamer's Avatar
That was the same boat I was in. When I priced out a factory replacement clutch versus McLeod RST, there was only about $120 difference between the two. Needless to say, I have a nice, red RST sitting on the table ready for install. No way in hell would I go with factory replacement clutch when I could have the RST twin disk for only $120 more!
Plus, the factory clutch has always slipped a bit on power shifting on 1-2 and 2-3. From day one.
This WON'T be a problem with the RST.
CiniZter
25
Apr 28, 2016 05:41 PM
MustangConvert11
Sep 30, 2015 08:01 PM
PonyMuscletang13
Sep 29, 2015 09:40 AM
