Has anyone run into legal issues with aftermarket HID's
Old Oct 4, 2007 | 01:08 PM
jmanpatsfan's Avatar
I am really looking forward to adding HID's to my stang, but I have come across a few articles that state they are illegal. My biggest concern is not from the police but from state inspection. Has anyone run into any issues with aftermarket HID's?
Old Oct 4, 2007 | 01:42 PM
WERKED 66's Avatar
only problem i have ever had was when i installed a set in a 96 sho they had no high.low function so that was the problem as long as your set does i see no problems...
Old Oct 5, 2007 | 01:17 PM
mustangbrad01's Avatar
You're not adding the Saleens right? It's hard to drive at night with all the newer audis, acuras with the hids,bmws. All the rich people have em. If you wanna add then just add. Who cares about the police. FT. I don't think it would be a good idea for the fogs, don't center light, just kinda dispurse. And also, fogs and headlights won't match color if you leave one unchanged. Isn't regular inspection just turning your lights on just to see if they work? With all the new cars out, HIDS are so common.
Old Oct 6, 2007 | 11:46 AM
Horrific_Ending's Avatar
just make sure they arent pointing up or you will more likely get pulled over. Mine face up just a little bit and i get flashed all the time.
Old Oct 7, 2007 | 12:13 AM
buffguy's Avatar
What is this state inspection that people keep speaking about? Beside the smoke check what does the state check? I live in california and i have never heard of a state inspection.
Old Oct 7, 2007 | 08:16 AM
Robbieg's Avatar
Just make sure you retain high/low beam function and you should be fine.
Ecostang
Nov 3, 2022 08:50 PM
Diode Dynamics
Jun 12, 2018 03:26 PM
RocStar69
Aug 21, 2015 07:33 AM
forceflow2
'10-14 Interior and Audio
Aug 4, 2015 08:02 PM
