GT vs V6 brakes? there a difference?
Old Jun 3, 2007 | 10:14 AM
jcopin's Avatar
the ford dealer parts guy said the GT and V6 have the same brakes all around. Is this true??
the reason i ask is that apparently at 35k miles the front rotor is slightly warped .. dunno why but new take off has ALL the front brake hardware for 200 bucks and the dealer wants 600 installed
Old Jun 3, 2007 | 10:31 AM
Louie's Avatar
Only the rear rotors and pads are the same on GTs and V6s, the fronts are different.
I say buy the kit from newtakeoff.com and install it yourself, although you don't really need to change the calipers.
Old Jun 3, 2007 | 10:37 AM
jcopin's Avatar
the fronts are different?? dont know if the pony package makes a difference
he sai same part numbers
oh well .. as long as the new take off ones will work i dont care lol
Old Jun 3, 2007 | 10:52 AM
cds06stang's Avatar
GT has 12.4" disc, while the V6 I believe has 11.8"
Old Jun 3, 2007 | 11:06 AM
jcopin's Avatar
well if that is true then the dealers people are retarded
so as long as i put the whole GT takeoff rotor caliper pad combo on together it should be ok right?
Old Jun 3, 2007 | 11:38 AM
ren274u's Avatar
I believe the only difference in the front is the rotor and the caliper bracket.
Old Jun 3, 2007 | 11:40 AM
DoctorQ's Avatar
2006 Mustang: Rear brakes identical... Front brakes different:
REAR BRAKES
V6 & GT = 300 (11.8 in) x 19mm vented disc, single piston 43 mm floating iron calipers.
FRONT BRAKES
V6 = 293 (11.5 in) x 30 mm vented disc, twin-piston 43-mm floating aluminum calipers
GT = 316 (12.4 in) x 30 mm vented disc. twin-piston 43-mm floating aluminum calipers
Old Jun 3, 2007 | 11:58 AM
jcopin's Avatar
thanks doc .. so no issues with just replacing everything with the GT fronts from newtakeoffs?
Old Jun 3, 2007 | 12:13 PM
Louie's Avatar
Absolutely none. All 2005 through 2008 GTs have the exact same front brake assemblies (rotors, calipers, pads, etc.). Just make sure you connect the brake lines properly and bleed the system. You might wanna take a look at the proper procedure to adjust the caliper pistons before you install the pads (i.e. do not simply push them back, they have to be turned!).
Good luck and keep us posted!
Old Jun 3, 2007 | 12:57 PM
kevinb120's Avatar
Still impressive that even the V6 has vented rear rotors, you have to spend a ton of money on a new import before you find them standard.
Old Jun 3, 2007 | 02:36 PM
2005mach1's Avatar
did the same change out last month, Replaced the rotors, after having them turned.[already knew they were good, but a good idea to make sure that they are true as well], replaced the caliper mounting brackets using the same caliper, saving the bleeding process. stops much better!
Old Jun 3, 2007 | 07:52 PM
jcopin's Avatar
lol every time i feel i know alot someone says something to make me feel dumb lol
i never did my own brakes ..what do you guys mean the calipers need to be turned??
Old Jun 3, 2007 | 07:54 PM
theedge67's Avatar
The calipers don't need to be turned, the rotors do. That means a machine shop will take the rotors and mill them down a few hundreths of an inch (if even that much) to make sure they are not warped at all and are totally true.
Old Jun 3, 2007 | 07:55 PM
karman's Avatar
ROTORS not calipers.
Old Jun 3, 2007 | 11:33 PM
jcopin's Avatar
even the new take off brakes?? shouldnt they be fine since they were just taken off a new stang?
Old Jun 5, 2007 | 05:45 AM
2005mach1's Avatar
rotors
Yes even if they were brand new take off. The set i had were laid flat, set there for 14 months, new takes offs, and still had a small bit of warp. Plus with the new turned surface it mates better with the pads. Just my 2 cents, but you dont wash you feet and put back on dirty socks do you?
Old Jun 5, 2007 | 08:58 AM
Bullitt995's Avatar
That's not what he meant!!! The caliper pistons operate on a groove and actually rotate in and out instead of coming straight out like most calipers. So you can't just clamp them in.
Old Jun 5, 2007 | 10:46 AM
Martimus's Avatar
Another way you can approach this is to replace the pads and rotors. I just did this to my car... replaced the stock pads and rotors with those I purchased from RotorPro's. Took less than an hour to complete and they look and stop GREAT!!!
Old Jun 5, 2007 | 04:46 PM
97svtgoin05gt's Avatar
Personally, if I'm going to spend any money at all on brakes for this car, I'm going to be replacing the factory garbage. It's definitely one of the weakest links on the car. Before spending $600 for the same crappy stuff, spend $1,000 and get REAL stuff.
Old Jun 5, 2007 | 08:39 PM
dkegel's Avatar
I had a pretty well sorted SHO with Wilwoods that saw a lot of track time over the years and I have to say that the Mustang's brakes are a lot better than one might think. I just flogged mine pretty hard at Gingerman Raceway (a 1.8 mile road cource) a couple weeks ago. Gingerman's very hard on brakes, but with SS lines, good fluid, and Hawk Blue pads all around the Mustang's brakes held up very well. Towards the end of the day (about 2 hours of total track time) the front fluid did get a little cooked, but I think some brake cooling ducts will help extend the fluid life for a longer day.
Just my $.02.
Dave Kegel
