Great. I stripped the nut.
Old Jan 6, 2007 | 02:54 PM
blackstang06's Avatar
Angry Great. I stripped the nut.
Well, I was trying to remove my stock headers, and I stripped one of the nuts connecting the catalytic converter to the header. I just had to express my anger. Does anyone want to buy a set of Mac shorty headers?
Old Jan 6, 2007 | 03:01 PM
05stangkc's Avatar
Try Working on a 35 Year old Muscle car with Crustation everywhere! Thats Frustration! Take a Deep Breath think about it and you will come up with a solution!
KC
Old Jan 6, 2007 | 03:32 PM
Boomer's Avatar
You have a bolt out or tap set?
Old Jan 6, 2007 | 03:59 PM
What is a bolt out? No, I dont have a tap set.
Old Jan 6, 2007 | 06:42 PM
05fordgt's Avatar
A bolt out is a tool that Craftsman makes. Its designed specifically to remove stripped nuts and bolts. You can pick them up at any Sears or Sears Hardware stores.
Old Jan 6, 2007 | 06:43 PM
PaulF's Avatar
Bolt out is a great tool...they sell some othe stuff that is equally as good, depending on how much clearance you have
Old Jan 6, 2007 | 06:46 PM
tom281's Avatar
Yep, and just FYI the K-Marts in our area carry Craftsman tools too.
Old Jan 6, 2007 | 06:55 PM
karman's Avatar
KC
BEEN THERE.
I do have bolt outs (screw extractors) and a tap and die set.
On some of the old (non-show) cars I've rebuilt I found piece that goes around both ends and pulls them together with some bolts. Sort of like 2 half flanges on each side.
Old Jan 6, 2007 | 07:02 PM
hang in there. It sounds like bolt out is the same as an easy out??
Old Jan 6, 2007 | 07:15 PM
Sorry you didn't research some exhaust notes in my 'How To' section.
Get some penetrating oil (the link in a spray can) and give them a good soaking, then let them sit for a few minutes. Nuts will break pretty easliy after that.
Good luck.
Old Jan 6, 2007 | 09:26 PM
Thanks man. The bolt isn't completely stripped. I may try this....does it work well?
Good luck.
Old Jan 7, 2007 | 12:09 AM
RedDragon777's Avatar
believe me it will work, use something like WD-40 or all-in-one and let it sit for about 5 min then try but not to much torque or you might strip more of the bolt just keep adding more oil till it gives in
Old Jan 7, 2007 | 06:53 AM
This is what I use, PB Penetrating Catalyst. You can find it at AutoZone.
It works like a charm!
Old Jan 7, 2007 | 08:19 AM
Import-Slaya's Avatar
I was about to say PB Blaster, too! After working on a 12 year old Jeep Wrangler with rust everywhere (heck, even the vinyl in Jeeps rusts!), I tried all the penetrating oils. PB Blaster worked so much better than the others.
Old Jan 7, 2007 | 09:40 AM
I'm just about to go and get some of this. Hopefully I wont screw this up!
Old Jan 7, 2007 | 10:55 AM
05stangkc's Avatar
The Vinal Rusts! I used to be a Jeep Parts Manager and I have seen Rust!
Old Jan 7, 2007 | 12:02 PM
Boomer's Avatar
Yeah a 'Bolt Out' ...Craftsman through Sears in Canada (and probably in the US too) great handy tool.
Same with 'Screw Out' (yeah I'm serious)
They are basically sharp sockets the will bit into the side of the bolt and allow you to remove it. Screw out, same thing but for screws if you strip them.
http://www.sears.com/sr/javasr/produ...id=00952166000
Old Jan 7, 2007 | 06:32 PM
did you get the bolt out?
Old Jan 7, 2007 | 08:01 PM
It's been raining all day today, so I didn't have a chance. We even had a tornado here in SC.
Old Jan 7, 2007 | 08:08 PM
GottaHaveIt's Avatar
Dang the Ford Gods if there are outta be Proud of the support people can find here especially from one example like Taco Bill, these sorts should be entitled to Ford credit or discounts Just Because !
