Global UP/DOWN Power Window Problem and Other Prob
Old Jan 26, 2005 | 03:16 PM
freyke's Avatar
:scratch: Hiya all...
I've had my new GT since Dec 29 and it is equipped w/the Active Anti-theft System, however the global window up/down function refuses to function from either the key fob or the key directly into the door... The dealer techs thought they had it isolated to a central control module (that was ordered over 10 days ago)... However after installed and re-programmed the problem persists... They're on the line (again) with the factory tech assist people as we speak... They've had the car since 8:30 AM and it is now 5:00PM.. Looks like they put in a long frsutrating day on this... Has anyone else experianced problems of this nature?
Of note a couple of other problem I had that were fixed/addressed today:
1) Exhaust rattle at 1500RPM on start up (until warmed up) sounded like the exhaust was touching the heat-shield under the car... This would only show up when the ambient air temp was below approx 35 deg F.
2) Optional medium-parchment interior leather passenger seat upolstry<sp?> was not completly installed. It seems they forgot to tuck-in the streach down strip that is located in the front bottom of the upostry.. In other words, the leather was real loose...
Anybody else have simillar probs?... Anyone,...Anyone, Bueller... Bueller...
Old Jan 26, 2005 | 06:04 PM
MTAS's Avatar
It's been pretty chili here in Tampa FL the past few mornings and I did experience this myself. Were they able to fix it? If so, how?
Old Jan 26, 2005 | 06:32 PM
Stubbies's Avatar
Hrmmm. I haven't tried the global up/down thing yet, gonna hafta give that a shot now just to verify it does work on mine. My leather seats are fine tho.
Old Jan 26, 2005 | 06:55 PM
freyke's Avatar
All,
Global Window Up/Down will only work for units equipped w/Active Anti-Theft... Like I stated, mine is equipped with Active Anti-Theft and all appears to work (motion sensor, etc) with the exception of the forementioned.. Car is still in the shop and looks like it will be there overnight... As for the exhaust rattle, service manager claimes (via phone) that this has been corrected along with the upolstry issue..... The real bummer here is they gave me a P.O.S. 2004 Toyota Corrola SE for a loaner... What a slug!.... I keep checking to see if I left the emergency brake on (he-he)...
Old Jan 26, 2005 | 06:57 PM
LilHog's Avatar
There is a section in the owners manual that explains how to reset the windows in the anti theft mode. It might be worth a try and see if it works, Hope it helps you.
Old Jan 26, 2005 | 07:13 PM
freyke's Avatar
Yep,
That stuff covers the bounce-back and short drop - all that is working as it should be... That was among the first things looked into.. :bang:
Old Jan 26, 2005 | 07:37 PM
Grantsdale's Avatar
Originally posted by freyke@January 26, 2005, 10:16 PM
Yep,
Its actually in a different place ... let me check the page really quick.
Old Jan 26, 2005 | 07:38 PM
Grantsdale's Avatar
Page 65, under "opening all windows"
Old Jan 26, 2005 | 08:06 PM
ravenblack67's Avatar
Old Jan 26, 2005 | 08:08 PM
My global up down feature does not work. I thought I was the only one. I fixed the loose piece under the seat myself. The exhaust rattle is annoying and will have to be repaired. Guess it's time to take it in. I knew I should have waited. On a good note, my shaker does not skip.
Old Jan 26, 2005 | 08:19 PM
ne2000's Avatar
My global up/down on windows works fine. the only issue ive had w/ my car is the fill up problem.
Old Jan 26, 2005 | 09:40 PM
Zig-Zag's Avatar
The manual notes on page 66 that the accessory delay feature must not be activated in order for the global window feature to operate. Unfortunately, it does not state the default setting, nor does it describe how to alter this feature.
Old Jan 27, 2005 | 06:22 AM
Texas Flood's Avatar
The paragraph on the accessory delay means that the global window feature will not work in the time between killing the ignition and opening the door. That is what it means by "activated". There is no way to permanently turn off the accessory delay feature.
Old Jan 27, 2005 | 06:55 AM
freyke's Avatar
Right-O... There is no setting the delay, that simply gets de-activated when you exit the vehicle w/keys in hand and close the door... At that point one should be able to utilize the global up/down feature...
Ravenblack,
Geeze, what was the build date on your car?.. Sorta the same problems... Mine is the 16th of DEC 2004... Sounds like some folks on the assembly line were thinking about the Christmas party instead of building cars...
Old Jan 27, 2005 | 07:03 AM
adrenalin's Avatar
Excuse my ignorance but what do you mean by "Global" up/down feature? I also have the anti-theft installed. I can rolldown my windows from the keyfob, but of course they don't go back up because that is not an option which is stupid cause if it starts raining you have to run out to the car to roll them up. If the windows are down and I try to reach inside the car, the alarm goes off and the windows roll up. The only issue I am having is the windows often need to be recalibrated. About every 5th time that I roll the window down and go to roll it back up it stops after a few inches. I then need to hold the up button until the window closes. I then reset the windows. Pain in the butt.
Old Jan 27, 2005 | 07:16 AM
freyke's Avatar
Adrenalin,
What you've just described sounds (to me) like a partially operative Global up/down... If you have not armed or simply disarmed the AAS then your windows should roll up as well as down by using either the key fob or the key in the driver's side door lock [hold lock towards front (lock postion) for 2 seconds to roll up, hold lock towards rear (unlock position) to roll down).. I'd check with my service advisor if I were you...
Old Jan 27, 2005 | 07:31 AM
holderca1's Avatar
Originally posted by freyke@January 27, 2005, 8:19 AM
Adrenalin,
You can only roll the windows down from the keyfob, you have to use the door lock to roll them up.
Old Jan 27, 2005 | 08:17 AM
freyke's Avatar
holderca1,
I stand corrected, I got the impression from the owners manual that it worked both ways from the fob...
as stated on page 65 of the owner's mannual
[QUOTE]Closing all windows (if equipped)
Note:This operation is only available using the door key in the driver door lock cylinder[QUOTE]
Old Jan 27, 2005 | 08:29 AM
holderca1's Avatar
Originally posted by freyke@January 27, 2005, 9:20 AM
holderca1,
I don't understand why they don't make it so you can roll them up with the fob, hold lock for 2 seconds maybe. I would rather have it be able to roll them up from the transmitter than being able to roll them down. As it has been said, if it starts to rain outside, and these storms can sneak up on you here in Florida, it would be nice to be able roll them up without running out to the car.
Old Jan 27, 2005 | 01:01 PM
MTAS's Avatar
Ravenblack,
I have the same build date and just today noticed the same thing on the passenger side front seat - loose leather in the very front.
