Gas Gauge Stopped Working!
Old Dec 6, 2010 | 11:13 AM
329VistaBlue's Avatar
I was driving my '07 GT one last time before putting it away for the winter today, and after my drive I stopped with a quarter tank to fill up in preparation for storage. After pumping approximately 12 gallons in the needle only went up to just over a half tank and stopped. When I got home I shut the car off and then restarted it to see if the gauge would show full after cycling the power, no luck, it came up to half a tank and stopped again!
Anyone else had this problem? If so how was it fixed?
Old Dec 6, 2010 | 12:23 PM
05YellowGT's Avatar
Sounds like a bad instrument cluster , a lot of us have had them go bad. Do a search there's a lot of info ...
Old Dec 12, 2010 | 12:23 PM
goldenpony's Avatar
You might try a 20 oz. bottle of Chevron Techron and fill (I would use preimum gas) and run until almost empty. If the first tank doesn't fix it, run a second tank of straight gas through and then follow with a second 20 oz.bottle of Techron & preimum gas & run until about empty. This is a known problem caused by sulphur in today's gasoline. I have read Ford recommends this procedure. Good luck.
Old Dec 12, 2010 | 12:34 PM
Flagstang's Avatar
Spam Connoisseur
I got هَبوب‎ed
its the fuel sending unit on these cars. they stopped using gold and started using silver in them and the sulphur clogs the unit.
my old 2006 mustang went though 3 of them under the tsb.
Old Jan 28, 2011 | 10:15 PM
MCK3125's Avatar
Switched gas from Chevron to BP fixed the problem. But it does freak you out when it happens...
GTown3r
1994-2004 V-8
Aug 30, 2015 08:04 AM
2012Kona
Aug 21, 2015 08:36 AM
DarrenGT
Aug 19, 2015 08:22 AM
John H
Aug 8, 2015 04:58 PM
retiredf5
Ecoboost
Jul 21, 2015 05:54 PM
