Flame Ball Shift Knob
Old Oct 7, 2007 | 05:32 PM
Marin7076's Avatar
Flame Ball Shift ****
I just installed a new shift ball from flameball.com. Before anyone says its to ricey for me - to each their own. I haven't seen this anywhere on the site. I hope everyone enjoys
http://s195.photobucket.com/albums/z...t=DSCF0209.jpg
http://s195.photobucket.com/albums/z...t=DSCF0210.jpg
Old Oct 7, 2007 | 07:15 PM
Tispco's Avatar
Looks good. I like it
Old Oct 7, 2007 | 07:18 PM
KR3259's Avatar
Thats not bad at all, nice conversation peice.
I like the Hurst shifter on my car.....much better than the OEM **** IMO
Old Oct 7, 2007 | 09:27 PM
XLmstang's Avatar
very nice
Thats looks sweet!! How hard was the install? Oh yeah, congrats on the first mod, it's all down hill from here.
Old Oct 7, 2007 | 09:36 PM
n8rfastback's Avatar
looks good in my opinion. nice and subtle but still different.
not too loud either.
Old Oct 7, 2007 | 10:38 PM
Humboldt Stang's Avatar
I like it.
You should look into getting an adapter to hold the boot up, but not right against the ****.
Bruce Roosa at koolknobs has one for 25 bucks I think.
Old Oct 7, 2007 | 11:34 PM
fordboy97f150's Avatar
thats hot...get it???...ooo man you can tell im tired lol...but serious, i havent seen one of those before, *two thumbs up*
Old Oct 8, 2007 | 08:15 AM
Im diggin that. Looks awesome.
Old Oct 8, 2007 | 11:27 AM
Ranger's Avatar
Originally Posted by Humboldt Stang
I like it.
Also have a flameball ****. I took two nuts with the right thread size and put a washer between them - then put the **** on. The top of the boot fit over the washer and holds it up. Have had it like 2 1/2 years and works fine.
Old Oct 8, 2007 | 08:03 PM
Marin7076's Avatar
Thats what I did just a 1/2 inch washer on top of a nut to hold up the boot. I had to pull the boot all the way to the top because it hides the led wire thats ties to the parking light makes for a clean look. thanks everyone.
Old Oct 9, 2007 | 09:06 PM
XLmstang's Avatar
I love you
Old Oct 10, 2007 | 08:04 AM
69Mach1-409's Avatar
Nice!
Old Oct 10, 2007 | 01:18 PM
RazorX's Avatar
Looks good. The flames look different in the second picture. Is that just different lighting between the two pictures?
Old Oct 10, 2007 | 01:40 PM
mseymour3's Avatar
Has anyone tried one of the flameballs for an auto shifter? Any way they would work with an auto or way too much altering to be done?
Old Oct 10, 2007 | 08:54 PM
SONICBOOST's Avatar
Originally Posted by XLmstang
I love you
hmmmm
Old Oct 11, 2007 | 05:22 PM
MELLOWYELLOW06's Avatar
Will it work on the Hurst shifter and if so where does the wire go?
Old Oct 11, 2007 | 09:36 PM
Marin7076's Avatar
When you place the order with flame ball and tell them what type of shifter you have I'm sure they can get the proper threading for it. But I'm sure its the same as the stock shifter threads. The problem with putting it on a hurst shifter would be the boot sits so low on the shifter and the wire would show. You would probably have to cut a channel down the side of the shifter that faces the radio and then tuck in the wire.
I used tacobills first couple of steps in the mgw shifter install to take apart the center plastic pieces and shift boot. ran the wire under the radio, zip tie it to the set of wires that run to the headlight switch. Then used the 2 quick connect splicers that were included with the led wire. I connected it to the parking light since that seemed to be the only one that had no amps when the key was on. the hot was the camel/tan wire and the ground was the back wire. here is the pic of quick splicer
http://www.clipsandfasteners.com/ser...-Scotch/Detail
Old Oct 12, 2007 | 01:52 AM
kh765's Avatar
That's not ricer. Looks pretty good to me.
Gigantor
May 11, 2023 07:31 PM
Jul 8, 2016 08:53 AM
K.A.I.N
Sep 25, 2015 03:27 PM
SterlingStunner
Sep 16, 2015 12:30 PM
earl610
Sep 6, 2015 05:48 PM
