exhaust mid pipe coupler clamps - bolt size?
Old Jan 1, 2008 | 09:51 PM
Burke0011's Avatar
Big Falken Tires
Anyone know offhand what the exact size of the bolts are on the exhaust couplers that hold the midpipe to the over the axle pipes? I was readjusting my axlebacks and pipes earlier tonight and snapped a bolt
Things should hold till I can get to a store tomorrow and get a replacement and was just curious if anyone had run into this issue before.
Thanks!
Old Jan 1, 2008 | 10:38 PM
hiznherponies's Avatar
Yea, I got experience with this!! I broke one off too, its a t-bolt (no hex-head) and about a grade-5. I grabbed a regular bolt about the right size from one of my many parts bins, turned out to be a little too long. Still worked though. The original bolt is metric for sure, my suggestion is to get a regular style bolt in stainless and at least a grade 5 that fits the hole size.
Old Jan 2, 2008 | 07:20 AM
Burke0011's Avatar
Big Falken Tires
awesome - thanks man
what was supposed to be a quick 45 minute adjustment turned into an hour and a half of tweak here, tweak there.... and then as I was finsihing up, then d**m bolt snapped
Needless to say I was ticked - but whatcha gonna do?
Old Jan 3, 2008 | 07:40 AM
GT Bob's Avatar
Amazing isn't it? I was buttoning up the install on my short tubes yesterday, and snapped a bolt... took what should have been a 30 minute finish up job to a 2 hours worth of work.
Old Jan 3, 2008 | 10:05 AM
Burke0011's Avatar
Big Falken Tires
LUCKILY I plan for the worst and bought two sets of FOUR bolts in two sizes at Home Depot
last night I discover how tight the T bolts fit into the clamp and how you have to PRY them the &$Y&$%^@% out.......
then I install the new bolt, go to lock down the first clamp (passeneger side), tighten up the new bolt, then tighten the old stock bolt...... SNAP.....
the second one breaks.......
take the sleeve clamp off, pry out the OTHER stock one, then add the second new bolt and get it all buttoned up - no probs or leaks
went all the way and did the other ones on the driver side too
Old Jan 3, 2008 | 03:38 PM
I've still gotta re-align mine (too cold out now) and replace all of the bolts with something stonger. I figure at least an hour's work, w/out any snafu's, that is!!
Old Jan 3, 2008 | 07:12 PM
Burke0011's Avatar
Big Falken Tires
as long as you have those &*@%#^@%# stock T bolts out of there, you will fly through it
Ecostang
Nov 3, 2022 08:50 PM
tony2014mustang
Aug 9, 2015 03:04 PM
BillyDaKid
V6 Performance Mods
Jul 15, 2015 12:50 PM
