excessive heat coming through firewall
Old Oct 17, 2006 | 09:20 PM
jimbobo's Avatar
i have a brand new 2007 GT with 180 miles on it and I have began to notice that there is exessive amount of heat in the cabin geneated through the firewall. Is this normal?
Jim
Old Oct 17, 2006 | 10:40 PM
2007redgt's Avatar
Mine does it too. I notice the car always seems to be warm inside. Not too bad for winter but in the summer
Old Oct 17, 2006 | 10:44 PM
05mustangman's Avatar
check the heater
Old Oct 18, 2006 | 07:06 AM
nynvolt's Avatar
My 05 does it also. If you look at where the cats are on these cars you can see why it heats up there. I bet you could put up some sort of extra heat shield, it has the silver "padding" looking stuff but appearantly it's not enough.
Not really a big deal, the AC in these cars are really good.
Old Oct 18, 2006 | 07:21 AM
IWantMyNewGT's Avatar
+1. I've only noticed it on longer trips when it gets the chance to really heat up. I've never noticed it on short trips around town.
Old Oct 18, 2006 | 08:18 AM
Dysan's Avatar
Can't agree more!!! The heat thru the firewall is horrible in these cars. At some point I'm going to try and put some sort of heat shield/reflector under the car.
Old Oct 18, 2006 | 08:50 AM
nbk13nw's Avatar
I think it is due to the cats being located where they are. Maybe some High Flo's or moving them back a bit will resolve the issue.
Old Oct 18, 2006 | 09:04 AM
pville piper's Avatar
I just went to Texas and back (from Alabama) in 95+ heat and I didn't notice it at all. The car cools down fast and is no wheres near as hot on the floor boards as my 97 GT was. It also has the ability to direct AC to the floor which my 97 didn't have.
Old Oct 18, 2006 | 10:01 AM
smokenpony's Avatar
I've had my 2007 for 3 weeks now, driven 800 miles, and I haven't noticed it
Old Oct 18, 2006 | 10:56 AM
Vermillion06's Avatar
I 've had mine since February, and to me it doesn't have any more heat through the firewall than any other late model car I've owned. What car did you have previously?
You can use the air conditioner and direct airflow to the floor if it bothers you.
My '67 Plymouth with longtube headers ,no AC, and no insulation: now that car had excessive interior heat!
Old Oct 18, 2006 | 01:30 PM
f1-cobra's Avatar
I've heard good things about SecondSkinAudio's Heat Wave.
http://www.secondskinaudio.com/cgi-b....cgi?pg=4&p=ps
3/4 of the way down the page.
Second Skin Heat Wave is a light weight, foil faced, fire retardant heat and noise insulation mat. This thermal-acoustic barrier is perfect for reducing heat and noise generated from vehicle engines and exhaust systems, as well as thermal insulation from the sun and radiant road heat.
Old Oct 18, 2006 | 01:59 PM
Smoooooooooooookin HOT!
Old Oct 18, 2006 | 02:26 PM
97svtgoin05gt's Avatar
They definitely run a little hot in the cabin, it's at least 30% worse than my '97 or any of my previous ones for that matter.
Old Oct 18, 2006 | 03:30 PM
steevr's Avatar
I can feel some heat there too on my '07.
Old Oct 18, 2006 | 03:34 PM
The Reverend's Avatar
Go down to your local Lowes or Home Depot. Get some Ice Guard. It comes in a 6' roll. It is used on roofs. It is asphalt based. This will sound dampen and temperature control the footwells. Remove the carpet and install it on the bare metal surfaces. It is like Dynamat but alot cheaper. Try it.
Old Nov 20, 2008 | 02:55 PM
GONE_N_60's Avatar
i get heat up through the transmission tunnel as well. My cupholders endup heating my slurpee to a juice yesterday. i was sad.
Old Nov 20, 2008 | 03:50 PM
houtex's Avatar
I just turn on max AC, then turn off the AC, and set the fan to 1.
I dunno why, but that just fixes it. Think it's the recirculating air being picked up, if you will, from the floor, and then thrown out the dash, and then out the windows.
You did say this was with windows down, right? I never notice this with the AC on and windows up...
Old Nov 20, 2008 | 04:59 PM
05fordgt's Avatar
Won't work, TRUST ME!
Old Nov 21, 2008 | 05:58 AM
dustindu4's Avatar
9 is not my lucky number.
just take your cats out?
Old Nov 21, 2008 | 07:45 PM
Rapture's Avatar
Our motors run hot! I hear it was normal/shrug
