Driver's Side Mirror squeaks
It doesn't sound like a loose part inside. It sounds like two things rubbing together and squeaking. Anyone else have this problem and figure out how to fix it?
If you can take a look behind the glass and actually see the motor/parts that move the glass, I would use some WD-40 on the parts you can see. Try to move the mirror as far left or right as possible look in there, it's worth a shot. If not it's off to the dealer
