Dreaded front end clunk?
Old Mar 25, 2007 | 12:49 PM
metroplex's Avatar
Does anyone know how to reproduce the dreaded front end suspension clunk? I can hear a "thud" whenever I turn the steering wheel when parked. Is this a sign the bolts are loose? What is the permanent fix?
Old Mar 25, 2007 | 12:54 PM
RadBOSS's Avatar
Only time I hear it is going over a speed bump in a parking lot.
Old Mar 25, 2007 | 01:54 PM
Ray Man's Avatar
Exclamation
My clunk also comes over rough roads at low speed. Here is a thread that talks about the front end noises. Not sure if your problem is covered though:
http://forums.bradbarnett.net/showthread.php?t=44888
Good luck!
Old Mar 25, 2007 | 02:13 PM
bad_monkeys's Avatar
In all likelihood it’s the endlinks. Use blue loctite and torque those puppies down.
Old Mar 25, 2007 | 02:31 PM
89Trooper's Avatar
Or take them off (along with the swaybar). No difference in driving or the amount of sway.
Old Mar 25, 2007 | 06:08 PM
Lime GT's Avatar
So what you're saying is Ford puts expensive suspension parts on cars that have no bearing on the ride quality.
Old Mar 25, 2007 | 06:12 PM
slipnotovk's Avatar
sarcasm?
Old Mar 25, 2007 | 07:12 PM
2L8IWON's Avatar
Have you lowered your car? I took mine to one of the best alignment places in my area and they say that it's something with my strut bushings or bearings. Easy fix and sounds about right.
No real impact in performance though, just annoying.
Old Mar 25, 2007 | 07:28 PM
sodaman's Avatar
well the clunks/popping etc in the 05' was the strut bearings, you could take hard turns or go around in a circle in tight formation and it would pop plenty. The clunking I was recently getting in my 06gt is the ford racing sway bars up front loosened up at the end links. I have not fixed it properly yet with air tools and loctite. But did find it quickly due to the good comments on here. I turned the wheels to the right and laid on the ground. I think I used an 8 mm socket to hold the end link from spinning while tightening with an 18 mm wrench I believe. Immediately I could tell it wasnt all the way tightened or loosened up. Just tightened it up by hand for now and all is well. Passenger side was good. I will get some time and hammer it on with some air and couple drops of loctite. The sway bars make the car much tighter, so It's no problem taking care of a few issues. Hopefully that will solve it. Good luck dont know if that helps.
Old Mar 25, 2007 | 07:54 PM
Hollywood_North GT's Avatar
Closet American
Is your car stock? I believe it is.
Determine if there is a TSB for your particular problem. Take it to dealer. Get it fixed.
Problem solved.
Old Mar 25, 2007 | 09:23 PM
Geos05GTvert's Avatar
I dont have a clunking in the front my clunking is in the read ever since I put my CHE UCA and LCA I get a clunking when turning.
Old Mar 26, 2007 | 05:22 AM
metroplex's Avatar
Problem solved.
I would never leave my car at a dealership for their mechanics to do exploratory surgery and then tell me "it is NORMAL". Been there, done that.
Old Mar 26, 2007 | 07:11 AM
89Trooper's Avatar
Simply... yes.
Originally Posted by slipnotovk
sarcasm?
Phil is still mad about my Chrome Taillight Bezels.
Old Mar 26, 2007 | 09:21 AM
YaoNYC's Avatar
hello,
im not sure if its clunking, but when i go over a bump the front of my car has a vibration..like something is not solid...
is that the clunking? i noticed it more when i did eibach pro springs and tokico d-specs...
Old Mar 26, 2007 | 11:51 AM
RadBOSS's Avatar
Make sure your UCA and LCA bolts are torqued to factory specification. This is a friction connection between the LCA/UCA bushing and the bracket, not a bolt shear which requires a precision fit. Shop manual recommends replacing these bolts after removal.
Old Mar 26, 2007 | 03:42 PM
Closet American
Well, at the end of the day, if there is a TSB for it, it's their responsibility, and you will need them to fix it anyway.
It's a question of finding a reputable dealer.
Fords4Ever
Oct 30, 2015 09:07 PM
FromZto5
75
Oct 5, 2015 02:27 PM
seaclam
Sep 25, 2015 01:29 PM
tbear853
Sep 8, 2015 11:18 PM
earl610
Sep 6, 2015 05:48 PM
