Double Turn Signal Click but the light isn't out!
Hey everyone, I've got a slight problem with my turn signal. It's double clicking as if to tell me one of my breaklights is out. I went back and checked while the turn signal was on and it just clicks faster but the all the lights are still working. (At first the middle light was out but then it came back on and hasn't gone out since.) It is on the passenger side of the car. I have and sct tune but I reflashed the car and the problem is still present. It is a 2005 GT. Are there any TSB's out for this issue? Any assitance, including giving me a dealer in houston that will do warranty work on a very slightly modified car, would be greatly appreciated!
1 Post
I had this problem last week. The right turn signal would flash very quickly on the dash compared to a normal flash indicator on the left side. I took the mustang into the dealership thinking perhaps the turn signal flash unit had to be replaced. Turns out that the only thing that had to be changed out was a burnt tail light bulb. Apparently when the signal flashes to quickly that is a sign that your taillight or front end bulbs have to be changed out. Cost me $21.83 for the diagnosis and new tail light bulb.
One of the crown vics that we run has the same problem, the right turn signal flashes quickly, however there is no bulb burnt out in the front or back. Everything works fine, it just flashes quickly. Very strange.
