Delete plate Question
Old Jul 22, 2007 | 01:18 PM
dly's Avatar
dly
OK I just won a stock set of Delete plates and a stock fuel rail on ebay for a buck and a quater. Can I take out the butterflies out of the plates??
Don't know weather I want to install these (if I can gut them out) or sell them. What are the pros and cons for having they install???
Old Jul 22, 2007 | 01:24 PM
bored out's Avatar
Is it true that gutted delete plates will hurt your lower end and give you a better higher end about 10 hp? This is what Brenspeeds website says.
Old Jul 22, 2007 | 01:26 PM
I read one guy that drilled out the butterfly valves out from the CMCV's and plugged the holes from them, sounds like a PITA though.
btw, you didn't win any delete plates, just OEM CMCV plates.
Old Jul 22, 2007 | 02:34 PM
PIKE2244's Avatar
I know this has been talked about, but I am waiting on some and just wanted to get anybodies updated opinion?
Old Jul 22, 2007 | 03:28 PM
tom281's Avatar
Yep you can remove the butterflies..... you'll still need a new tune.
Old Jul 22, 2007 | 04:03 PM
bored out's Avatar
Why would delete plates hurt your lower end though?
Old Jul 22, 2007 | 07:53 PM
what were your search words on ebay???I would like to do the same thing.
Old Jul 23, 2007 | 11:00 AM
jayguy's Avatar
Removing the butterflies (or installing the delete plates) allows the air to flow in better with no blockage, but at lower rpm that means the air is traveling slower through the larger opening. That is what takes away some torque. The stock butterflies are there to cause the air to speed up at the lower RPM's by closing the pathway a bit, creating more torque. At higher RPM the air is able to flow better with no blockage, thus allowing the engine to create more power.
I've noticed it on my car, not really that the tires don't spin as much, but that after about 3K the car really picks up and moves, it's not quite as linear as it was before.
But I love it, and won't change back.
Old Jul 23, 2007 | 03:46 PM
dly's Avatar
dly
Was looking for stock fuel rails and found this
http://cgi.ebay.com/ebaymotors/ws/eB...1141790&rd=1,1
Old Jul 23, 2007 | 11:24 PM
Shelby10''s Avatar
I did not feel any low end loss whatsoever.... All I felt was more power in the top end but no loss... maybe its just my car though
Old Jul 24, 2007 | 07:37 AM
PIKE2244's Avatar
Do you notice any issues with taking it in for service? Does ford give you a hard time w/ the new Delete plates?
Old Jul 24, 2007 | 10:39 AM
There is a huge difference btwn all the Ford places. Some get really POed if your car is modded, some dont care and they admire it. Kinda weird.
Old Jul 24, 2007 | 12:40 PM
PIKE2244's Avatar
Yeah it just sucks not knowing what you are going to get when you go to the dealership...
Cobiecane
Oct 23, 2015 08:44 AM
AJ_Trevino15
Sep 28, 2015 07:51 AM
