De-Winterizing
Old Mar 7, 2007 | 01:47 PM
MN_Mustang06's Avatar
De-Winterizing
Who's getting ready, and what are you doing to get ready to get your car ready for spring? Probably 2-3 weeks till I can get my stang out (minnesnowta here). I am really jonesin for car season to start!!
Old Mar 7, 2007 | 01:50 PM
DynamicmustangGT's Avatar
check your fluids, tire pressure, and of course your motor you need to check your 0-60 and your burn out skills then clean the car up and hit the roads
Old Mar 7, 2007 | 01:53 PM
Speeddmn's Avatar
dont forget to swap the winter air in the tires for summer air, easy .10th in the 1/4!!!
Weather here isnt bad so I drive it every day. Make sure all your fluids are up to par and change the oil.
Old Mar 7, 2007 | 01:57 PM
I changed the oil the day I put it away. Do you think it needs to be changed when I pull it out for the first time this spring ??
Old Mar 7, 2007 | 02:02 PM
Speeddmn's Avatar
better to be safe then sorry. And like the old saying goes 3k miles or 3 months whatever comes first.
Old Mar 7, 2007 | 03:28 PM
theedge67's Avatar
If it has not been run since you put it away, no problem, you would just be wasting oil. If you ran it a few minutes every week or something like that, change it. The oil will get water in it, and could be nasty for your engine. When it only runs for a few minutes (less than 20) the oil never really gets hot enough to burn off the moisture that accumulates in it from cold startup.
Old Mar 7, 2007 | 03:29 PM
I decided on not starting it all winter, and I just putting the charger on it once a week for about 24 hours. I think the oil should be nice and clean, I will run it as is.
Old Mar 7, 2007 | 03:35 PM
theedge67's Avatar
A little trick I learned once from a mechanic friend of mine is if the engine has not been run in a long time, all the oil has drained to the pan and nothing is left sticking to the engine parts. To compensate, pour a little oil into the engine at the filler cap and let it drain down into the engine for about 30 seconds before you start it. Doesn't need to be much, maybe 1/4 quart or even less. Just enough to get some liquid on some parts, you know?
It's not perfect, but it is better than nothing.
Old Mar 7, 2007 | 03:39 PM
Thats a good tip, and a good idea, thanks edge67.
Old Mar 7, 2007 | 05:55 PM
metroplex's Avatar
So what happens to the other cylinder head?
You could pull the fuse for the ignition and crank the motor over several times. But modern synthetics and synthetic blends should give a decent enough boundary film on the rotating parts, and flow quick enough after startup to lube all of the parts.
Old Mar 7, 2007 | 06:02 PM
theedge67's Avatar
Like I said, it's not perfect, but it is better than nothing. 5 seconds without oil is 5 seconds too long if you ask me.
Old Mar 7, 2007 | 06:06 PM
metroplex's Avatar
We have a 5 year powertrain warranty. Besides, if you're out of warranty and your engine manages to wear out because of cold starts like this, it would be a good time to beef up the internals and add a supercharger.
Old Mar 7, 2007 | 06:22 PM
theedge67's Avatar
3 years for me and MN Mustang06. My warranty is already gone though, I drive too much.
Old Mar 8, 2007 | 06:59 AM
First Stang's Avatar
I have read that you should change the oil after storing for a while. For example see: http://www.teammiata.com/libs/Winter_Storage_Tips.htm
Looking forward to getting mine out, hopefully in a few weeks.
Old Mar 8, 2007 | 07:07 AM
Galaxie's Avatar
I Have Admin Envy
The long term forecast is looking good up here in Toronto
If it keeps up, I will put my car back on the road by the end of the month. Hopefully we a few good rains to get the salt off the road. This is the worst part when storing the car... waiting for the chance to get it on the road.
As for the oil, I had it changed right before I parked the car, I really see no point changing it again. The plan once I pull the car out is to clean the air filter, check the tire pressures, take it on a long drive and get everything nice and warm, then give it a thorough wash and detail. Then go for another drive
Old Mar 8, 2007 | 07:41 AM
+1 Galaxie
Old Mar 8, 2007 | 07:44 AM
05fordgt's Avatar
I keep my car in a nice warm garage, out of the elements. When the roads were clear, I would get her out and take it for a ride, just to get a run in her. Now, once the weather gets warm here in the SE region of PA, car will come out, and get a nice bath, and 2 coats of wax!! Then I'm all ready for the GOOTC run to Maryland International Raceway on the 24th of March!!! As it stands now, 65 Mustangs heading down I-95 in a convoy!!! Should be over 100 at the track at the show! I can't wait!!
