Cracked fog lights
Old Nov 17, 2008 | 11:04 PM
Antigini-GT/CS's Avatar
Founding MOTM
Committee Member
Cracked fog lights
Has anyone had this problem? Months ago I noticed my fog lights were beginning to crack slightly and over time just got worse. I finally took my car back to the dealer today for warranty work on the alarm system, the aux port, oil change/fluid fill and the fog lights. I'm just hoping they don't try to pull some crap about them not being covered for whatever reason. Anyway, here are some pics of what they look like. I never changed out the stock bulbs so its definitely not from bulb heat.
Passenger side.
Driver side.
Old Nov 17, 2008 | 11:26 PM
El Paso heat
Old Nov 17, 2008 | 11:44 PM
blkstang06's Avatar
I think there have been some other posts about this issue....
Old Nov 18, 2008 | 09:58 AM
scramblr's Avatar
Weird, first I saw this on these fogs. Within weeks of having the car I covered the headlights and fogs with a clear-bra type of plastic to protect them from rocks. But these sure doesn't seem like it's from impact.
Old Nov 18, 2008 | 11:07 AM
nynvolt's Avatar
Those are cracks caused by heat. If you have not changed out your bulbs you should be covered no problem. Strange, this is the first I have seen like this without the person having changed out to super bright bulbs.
Old Nov 18, 2008 | 11:52 AM
Founding MOTM
Committee Member
Considering this happened with my regular bulbs(and possibly the El Paso heat), i'm a little concerned about the Silverstar bulbs I bought. I changed out the headlights and not a single issue with them since day 1, but I don't want this issue to happen again.
Old Nov 18, 2008 | 12:09 PM
GottaHaveIt's Avatar
Now you didnt change from a facory bulb I hope cause if you did & the other puts out more heat Too bad is what they ewill say if they are original & it looks like heat to me , I'd think they'd have to.
Old Nov 18, 2008 | 12:10 PM
sorry I had to re read put regulars back in & lie i guess, just maybe there is an aftermarket cover that will take the heat ?
Old Nov 18, 2008 | 02:38 PM
Antigini I have seen this before on here, but it was before I was a member, maybe some time last year. Your photos look almost the same as the other persons. And I shouldn't have said El Paso heat, those Mustangs in Arizona would all have this problem then. You got bad lenses. I'll need to look at mine more closely. They are in the attic as I put a Bullitt grille on a while back. But I too have the '07 GT/CS so they might have come off close to each other, who knows. I really don't remember anything like this.
One last question,
Do you drive with your fogs on alot? Cause I never did. I got tired of getting flashed with high beams.
Old Nov 18, 2008 | 02:46 PM
Founding MOTM
Committee Member
I use my fogs all the time and i've noticed the lenses do get VERY hot.
GottaHaveIt - I never switched out the fog bulbs since I noticed the cracks before and decided to take it to the dealer before I installed them.
Old Nov 18, 2008 | 02:51 PM
Do you clean them with ammonia based windex, I think that can cause the acrylic or polycarbonate to dry out and crack, I think. Again I'm just throwing out ideas, not trying to make it your fault.
Old Nov 18, 2008 | 11:09 PM
Founding MOTM
Committee Member
Nope. I never use any sort of cleaner to do the lenses.
The dealer kept my car overnight again. Its been a depressing two days. They are going to replace my aux port under warranty and the service guy who was helping me said they're waiting on Ford to give the go ahead to replace the ENTIRE fog light assembly under warranty as well. Since it'll take a few days to get the parts in, i'll take it back later next week for them to replace everything.
Old Nov 18, 2008 | 11:11 PM
I hope they change it. It would be the right thing for them to do. Best of luck to you.
Old Nov 19, 2008 | 11:52 AM
Founding MOTM
Committee Member
Just got a call from the dealer. It was approved for replacement. Now I can go pick her up.
Old Nov 19, 2008 | 01:01 PM
Awesome. Sounds like a great dealer.
Old Nov 19, 2008 | 01:05 PM
One last question,
well have to compare our 07 GT/CS vin's one day
Si Senor.
Old Dec 15, 2008 | 05:33 PM
Boltzman's Avatar
This happened to my headlite covers. It was from tint that I had on them
Old Dec 15, 2008 | 07:17 PM
backafter20's Avatar
My fog light lenses did the same thing. I used my fogs constantly, and did get flashed quite often, so I put a vinyl cling tint on them for awhile. I'm not sure when they crazed, but I didn't notice it until after the tint was removed. The dealership did replace them, but not until after trying to tell me that I had used chemicals on them that caused the cracking. They never asked about tinting, and I didn't tell. Anyway, maybe not a great idea to tint the fogs...
Old Dec 16, 2008 | 05:46 AM
Arkady001's Avatar
Not a good idea to drive with them constantly switched on - if you want to do so, I'd think about putting in a lower wattage bulb rather than brighter ones - these lights are designed for short-term use only...i.e. in fog.
I don't know about the various State's legislation regarding fog-lights over there, but in Europe if you have fogs on and it's not foggy, you'll be pulled over by the cops and fined quite heavily as it constitutes a hazard to other road users...
