Coolant
Old Nov 6, 2016 | 12:47 AM
dancorneliu79@yahoo.com's Avatar
Coolant
Hello, its time to change coolant on my 2008 gt and all i can find in my area is this
SHELL ZONE DEX COOL EXTENDED LIFE with bittering agent . CONCENTRATE.
Anybody has anyideea about this stuff ?
And also planning to change sparkplugs. Any thoughts on this ?
Thank you !!
Old Nov 6, 2016 | 07:54 AM
NC14GT's Avatar
Dexcool is GM related. I use that in my TransAm and C4. When I changed the coolant in my GT I went to the Ford dealership and bought the correct coolant for my 2007 (so many colors and types for different Fords). No mistakes. If you need a better price, I'm sure many auto parts stores have the correct type, just make sure. Good luck!
Old Nov 6, 2016 | 11:58 AM
Problem is i live in Romania, Europe and dont have to many dealers know about mustangs. So, please can you be more specific about antifreeze ? What did you use on your mustang ?
Old Nov 7, 2016 | 06:20 AM
05YellowGT's Avatar
I use Zerex G05 in my 05
Old Nov 8, 2016 | 05:26 AM
NC14GT's Avatar
Didn't know that. This is what I have sitting in my garage and what I used when I changed the coolant in my '07 GT. You mix this 'concentrate' one with distilled water.
http://www.ebay.com/itm/Motorcraft-C...dXvKIM&vxp=mtr
Old Nov 8, 2016 | 05:43 AM
THANK YOU !
https://www.amazon.de/Motorcraft-K%C...eeze%2FCoolanT
ITS DOUBLE THAN YOURS BUT...IT IS WHAT IT IS !!
Old Nov 8, 2016 | 05:56 AM
did you flash the sistem before ?
Old Nov 8, 2016 | 06:36 AM
Silly question... does it really need to be changed? I mean I always heard antifreeze does not go bad. Yes some people think it needs to be changed at a certain point but does it really?
Old Nov 8, 2016 | 07:28 AM
Radical540's Avatar
You'll need "Motorcraft Orange" concentrated coolant. (which is NOT synonmous with Dex-Cool.).
Old Nov 10, 2016 | 05:21 AM
NC14GT's Avatar
I personally didn't flush the system in mine. Just drained. The reservoir was very clean and only about 30,000 miles on the car. I did it due to the age of the coolant. ** For Glenn too in his post above. My understanding is that the efficiency of the coolant lessens as it gets older, especially getting near the 10 year mark. Our '07's are at that point, probably built in '06. I've never had any mechanic ever tell me to leave it alone indefinitely. Even the 10 year 100k miles GM Dexcool claims are inaccurate with some real horror stories out there.
Old Nov 10, 2016 | 07:20 AM
Thanks NC07 and point taken. I saw a post around here that said for current in the fluid with an amp meter.
Old Nov 13, 2016 | 01:05 AM
Today i received the ford gold coolant from amazon.
So, after flushing the sistem whats the corect % mix do i have to refill, considering that a good amount of distilled water will remain in there ?
And also when flushing the sistem its correct to fill and drain in the same time and start the engine,until the water will be clear?
Old Nov 15, 2016 | 06:24 AM
NC14GT's Avatar
That's pretty quick delivery time.
There should NOT be a 'good amount' of water remaining in the system if it's drained properly. You want it 50/50 with your concentrated gold coolant. If you want to go 55% coolant to 45% water I doubt you would hurt anything but you want to be as close to 50/50 as possible for maximum efficiency.
