Is This Common?
Old Nov 10, 2005 | 10:46 PM
Wildstang's Avatar
I searched and came up with nada. Wondering if there are any TSB's or if anyone else has experienced this behavior on their 2005/2006 GT.
After a cold start and heading out to the highway, I have noticed a little vibration/shake in the steering wheel. I have not had my first oil change yet, but plan on having them check it when I take it in if it has not gone away. It is something that I have only noticed after the temp has slipped down below 50-ish.
Very strange - almost as if I got flat spots in my wheels from sitting because it does go away after it's "warmed up." Odd thing though is that it has not sat very long.
Anyone?
Old Nov 10, 2005 | 11:16 PM
grrr428's Avatar
If you do a search on "flat spot" and "tires" you should find something here, I saw something in the "Issues" area. Performance tires are softer and (I'm guessing) they are more likely to flat spot temporarily.....not the braking type of flat spotting.
Old Nov 10, 2005 | 11:43 PM
emperorjordan's Avatar
I have the EXACT same thing. only till it warms up, and only since it has been cold in the morning. EXACT same symptoms.
Old Nov 11, 2005 | 12:30 AM
jwede's Avatar
Me too, exactly the same.
Old Nov 11, 2005 | 01:20 AM
tom_vilsack's Avatar
Have you checked tire pressure...with it being cold out now this will lower the pressure...maybe you just need to add some air?
Old Nov 11, 2005 | 04:17 AM
WERKED 66's Avatar
i am have the same issue.tire pressure is pefect...
Old Nov 11, 2005 | 06:13 AM
KB9KHM's Avatar
I also have the exact same issue with my 2006 GT.
Old Nov 11, 2005 | 06:22 AM
1st Stang's Avatar
Same here.
Old Nov 11, 2005 | 06:41 AM
atomicskiier01's Avatar
yup, every day
Old Nov 11, 2005 | 07:15 AM
Big-Foot's Avatar
Tires should be inflated when cold to the max tire pressure listed on the sidewall - not Ford's recommended tire pressure. Ford and Firestone are still battling over this and Firestone will ultimately win.
I've had the same flat spot issue until I bumped up the tire pressure.
This is particularly important in the geographic areas that get very cold.
Old Nov 11, 2005 | 01:41 PM
Scarpi's Avatar
I thought tires were supposed to be inflated according to the label on the car door jam. For my car it states 32psi cold and that's what I do. I don't seem to have any problems.
Old Nov 11, 2005 | 05:14 PM
grrr428's Avatar
You're in Arizona!
Hey, I'm in San Diego, so I don't have this problem either. But I remember the cold days back in Minnesota. It's a fairly common problem. if it is really annoying you can get harder compound winter tires.
Old Nov 14, 2005 | 10:31 AM
jefffro's Avatar
I have the same exact problem with my tires at 32 PSI. What pressure are you running Big-Foot? I couldn't find a max pressure listed on the tires?
Old Nov 14, 2005 | 10:35 AM
MJC302's Avatar
I run my fronts @ 36 psi cold...no problems.
Old Nov 15, 2005 | 09:54 AM
mrkabc's Avatar
I run all four tires at 35 PSI... no problems here.. but then again I am in Los Angeles...
Old Nov 15, 2005 | 04:38 PM
97svtgoin05gt's Avatar
I have believed from the beginning that the AAI wheel balancer doing the balancing at the factory is off. When I picked my car up at the dealer, I had this shake. It was between 50 and 60 MPH. Above or below, no problems. I had the dealership rebalance the wheels and sure enough, they were off. Once they did that, car was fine until of course I changed the wheels. I haven't yet had time to get the exchanged wheels balanced.
Take it to the dealer and have them balance the wheels.
Old Nov 17, 2005 | 11:10 AM
vistablue mustang's Avatar
Got the same problem just noticed it today, guess thats another thing on the list to have the dealer check.
Old Nov 19, 2005 | 12:06 PM
"05 Saleen's Avatar
I have the same thing, also had it on my '03 Lightning. FYI I have Pirelli's on the Saleen.
Old Dec 14, 2005 | 12:43 PM
65205's Avatar
I have noticed a slight vibration in the steering wheel when
I first drive off, but I always thought it was the highway in
front of my subdivision because the vibration always goes
away. The road was resurfaced the week I bought the car,
and I just figured they did a poor job. Cold not an issue here,
it happens at all temps.
Old Dec 14, 2005 | 07:25 PM
lodom's Avatar
If it stops after driving for a while, then it is in the tires. Regardless of temp outside, the tires are cold. Some tires tend to flat spot after sitting for a while. I wouldn't worry about it, but after about 5k miles, I'd suggest having the tires rotated and road force balanced on a Hunter machine.
