Clutch/Gear Q
Old Nov 28, 2007 | 07:33 PM
dac64's Avatar
Clutch/Gear Q
New 2008 GT/CS 3000 miles.
I was starting to notice it was getting harder to change gears. The other day I am shifting from 2nd to 3rd and I hear a grind, sort of like I missed the gear or was only half way in. But that was not the case, pedal all the way down on the floor and just shifting into 3rd. If I move into 3rd slowly, I can feel that same grind. I can avoid it by shifting more quickly and push the stick up with more force. I never really noticed this until that other day when I heard and felt that grind.
If a clutch peddle is all the way down, should I EVER feel the gears spinning at all, even if I shift very slowly?
Old Nov 29, 2007 | 12:11 AM
theedge67's Avatar
It's probably normal. You live in NJ, it is getting colder there, and I would suspect the cause is colder temps. Try and keep track of when it does this, and observe if it is when cold, warm...been driving for a while, or just started driving.
Old Nov 29, 2007 | 04:56 AM
GTMark052's Avatar
Hey Dan, If it's a quick grind, I'm getting the same exact thing, but only when the trans is cold. So you're not alone.
Old Nov 30, 2007 | 06:49 AM
dac64's Avatar
Thanks Steve, I didnt know low temps had an effect on this.
Hey Mark, yes it is a quick grind mostly from 2nd to 3rd. I guess it must be the cooler temps that arrived this week.
