Cluster gauges dim!!!!!!!!
Old Mar 14, 2019 | 12:57 PM
Pauls02's Avatar
I have a 06 Roush that the instrument cluster gauges are dim but but radio time display and all other non Roush dash lights work perfectly and work as should when you use dial to dim and brighten. The white backing on Roush gauges seem like they don’t light at all! The red u see in photos do dim and brighten. See photo of them at full strength. Fuses are fine, was thinking headlight rheostat but lights do dim and brighten turning ****. Anyone else have this problem.
Old Mar 18, 2019 | 09:55 AM
Lime GT's Avatar
Check the following fuses: in BEC fuse box engine compartment; fuse #44-10amp and fuse #67-30amp. In the SJB right kick panel; fuse #6-5amp and fuse #19-5amp. I think fuse #19-5 amp may be the one causing problems. Check for signs of water intrusion on the SJB.
Old May 17, 2021 | 03:51 PM
06roush2's Avatar
cluster gauges also dim!
owner of a 2006 stage 2 roush with same cluster gauge issue. green backlight was intermittent, but now not operational at all. was a fix found? any help and/or assistance would be appreciated.
bbunt302
05-09 My Color, IUP & Gt-500 Cluster, Gauge Face Topics
Sep 29, 2023 09:36 PM
VGMStudios
Aug 31, 2020 10:43 PM
Imatk
Sep 6, 2010 02:31 PM
1 COBRA
Mar 24, 2008 09:17 PM
Cleveland
13
Sep 23, 2005 07:18 PM
