Check engine light (P2020 code) anyone experience this?
Old Dec 30, 2014 | 10:45 PM
mrp5150's Avatar
So the check engine light came on again in my '08 Bullitt, so I took it to get scanned a second time. The first time the check engine light had went off so nothing came up, but this time it stayed on and it came up as P2020 - intake position sensor. Has anyone ever experienced this? The check engine light is off again, but I want to get this fixed if it's a problem. Before I take it into a shop that will take a look at it more in depth I just wanted to see if anyone here has any advice or experience on this issue? Any help is much appreciated.
Old Jan 3, 2015 | 05:49 PM
KdF's Avatar
KdF
Have ya cleaned the throttle body yet?
Old Jan 4, 2015 | 08:10 PM
mrp5150's Avatar
It ended up being the intake manifold runner control module. I ended up buying a new intake manifold from New Take Off since it was cheaper than buying the module...and the manifold comes with the module.
Old Jan 5, 2015 | 07:09 PM
ford4v429's Avatar
legacy Tms Member
if those things start failing, hope some of the guys that bought Charge Motion Control Valve Plates saved their old actuator modules - bet a lot of them got tossed out
Ive been thinking it might be smart to get a spare manifold or two...long term the plastic manifolds could be a 'wear item', know theres been a few models that tended to crack...
Old Jan 5, 2015 | 07:22 PM
how did you figure that out?
kylerohde
Jun 24, 2021 10:57 AM
Diode Dynamics
Jun 12, 2018 03:26 PM
STOERKEL
Sep 11, 2015 11:38 AM
Will3212
Jul 16, 2015 10:30 AM
