Changing Spark Plugs Problem,
Old Dec 24, 2015 | 03:19 PM
tang65c's Avatar
Finally changing spark plugs in my 07 gt Got four of them out by turning then spraying, waiting, turning, and spraying etc. Three of them the threads on the spark plug came out and the spark plug stayed in. Did not break, was able to put the threads back in and tighten back up.
Question is how to you get the plug out after the threads come out?
One I could not get loose so sprayed and waiting till I try it again.
Thanks in advance, Keith
Old Dec 24, 2015 | 03:44 PM
houtex's Avatar
Ah yes, the old two piece spark plug problem.
You need to read this:
https://themustangsource.com/forums/...-plugs-522706/
All of it. It details this problem and how to deal with the plugs. There is a tool you need to acquire, either borrow or buy, to do this, and then you just have to have time, patience, and it'll work out.
Hope that helps ya, and good luck, man!
Old Dec 26, 2015 | 03:18 PM
tang65c's Avatar
Had to buy the tool
Ending up breaking off 4 of the spark plugs. Purchased the tool at napa.
Did a wonderful job. Started it up Idled rough for a little bit then smoothed out. Ran it out the road and ran just fine. Thanks for the Help.
Old Dec 26, 2015 | 07:48 PM
Cavero's Avatar
Glad to hear you got it settled OK. Out of curiosity, how many miles were on those plugs?
Old Dec 26, 2015 | 07:50 PM
houtex's Avatar
Good to hear!
Old Dec 27, 2015 | 07:43 AM
godspunk32's Avatar
You can probably turn around and sell that tool for purchase price. I bought mine on a Friday, did the plugs on Saturday, and sold it on Sunday for exactly what I paid. There are a lot of cars with the original plugs, and a lot of people that have or will have this problem.
JR
Old Dec 27, 2015 | 10:27 AM
tang65c's Avatar
I had 96,000 miles on the car. Still ran fine but I figured they needed to be changed. You could tell how worn they were when compared to the new ones.
Old Dec 27, 2015 | 03:38 PM
m05fastbackGT's Avatar
Glad the Lisle tool worked well for you.. Your also fortunate that only 4 plugs broke with 96k miles.. Unless you end up keeping the car indefinitely ? Chances are you won't be doing another spark plug change anyhow
Old Dec 27, 2015 | 08:05 PM
Cavero's Avatar
Yeah, IIRC, the service manual calls for a 100k interval on the plugs so you were pretty much due. After hearing all these horror stories, I chickened out and changed mine at 47k w/ motorcraft and again at 85k with
E3 plugs E3 plugs
. Not because of any purported HP gains but because they're 1-piece plugs so they're a lot less likely to break.
Old Dec 28, 2015 | 06:45 AM
godspunk32's Avatar
I replaced my two-piece plugs at like 30k miles with the Copper Brisk Racing plugs (one-piece). Unfortunately, they're only good for 20k miles, so I replaced them with the standard Motorcraft plugs around 50k. I traded it into the dealer when I got my 2016, so not my problem anymore!
JR
Old Jan 1, 2016 | 05:47 PM
tbear853's Avatar
From: the beautiful "Shenandoah Valley of Virginia"
I've had my '07 FX4 5.4 for a few years and while Ford once said 100K, I hear that now Ford says change them by 60K. Many mechanics I know agree .... get them early. Just bought the '08 Mustang a couple years ago ... and I bought a Lisle Tool about same time. This Spring of 2016 the '07 5.4 will have a little over 55,xxx miles and the Mustang may see 30,xxx by Summer .... so I'll swap out their plugs this Spring and then ...... sell the tool maybe?
Old Jan 8, 2016 | 09:35 PM
Gigantor's Avatar
When I replaced my plugs someone on the forum said I'd have a 50/50 chance that it would break off and wouldn't you know it 4 out of 8 broke. The Lisle tool did do the trick. Although OP I would have changed the COP's at the same time. Mine had about 86K before they started to go. One went totally dead and another wouldn't fire all the time.
Old Jan 9, 2016 | 07:15 PM
ford4v429's Avatar
legacy Tms Member
might be luck, but I just replaced one coil on my mercury- 2002 with 175,000 miles on it.
still havent changed my Mustang plugs yet(06/75k miles), cars parked for winter, maybe tomorrow will be the day...got the OTC collet tool thats supposed to help PREVENT breakage, and the Lisle puller just in case, and MSD plugs...still have a set of screwed up champions I shoulda returned years ago- they were complete garbage- metal shavings crimped under the seal, one wasnt even fully threaded, likely woulda damaged the head if installed, plus all the tips were off center- woulda had to gap diagonally... the MSD one piece plugs are jewelry compared to champion- iridium not platinum tipped though...
Old Jan 9, 2016 | 08:22 PM
houtex's Avatar
In case it matters, I am on 130K+ now miles, original coils, no issues...
...aaand now I'll have jinxed it. Dang.
Old Feb 2, 2016 | 04:58 PM
tang65c's Avatar
If any one needs the tool for this I will sell you the one I used. Make me an offer!
Old May 6, 2016 | 10:45 PM
rick57's Avatar
asked dealer
I asked my dealer about this. they say they never heard of such a thing as them being hard to get out or breaking.
so for the $150 price to change em ill let them do it i think
rick57's Avatar
asked dealer
I asked my dealer about this on an 08 . they say they never heard of such a thing as them being hard to get out or breaking.
Old May 7, 2016 | 12:24 AM
mrkabc's Avatar
2008 model year uses a one piece plug that doesn't break. We are lamenting having the pre-12-2007 build design of wretched 2 piece plugs that break off when you look at them.
Be glad!
Old May 7, 2016 | 04:45 PM
Buckshot Barry's Avatar
Be glad!
So technically that's 2008 Job #2 V8 Mustangs. 2008 Job #1 V8 Mustangs would have the 2 piece plugs.
I think the production date would be post 12/03/2007 from this thread
http://www.blueovalforums.com/forums...ease/?p=238416
Old May 8, 2016 | 12:48 PM
goldenpony's Avatar
OP, what new plugs did you put back in? Did you use the nickle anti-seize?
