Can i put a cdc shaker on a supercharged engine?
Where does the air from the shaker actually go in this setup? The Vortech eliminates any airbox, correct?
here is the Fang Performance, the air from the scoop goes straight into the filter of the vortech through the ducting in the hood
even though that is the procharger kit a vortech will still fit and the filter will be in the perfect spot for the ducting on the hood
