Burnout!
Guess you didn't mind warping a rotor or killing your brakes and in another post you mentioned dry pavement. Definately not dry pavement there. Did you use a soap/water mix? BTW, nice 1-wheel peel. You might want to see if you can glue some of that rubber back onto your tire
![Biggrinjester](https://themustangsource.com/forums/images/smilies/biggrinjester.gif)
Originally posted by adrenalin@May 2, 2005, 2:12 PM
Guess you didn't mind warping a rotor or killing your brakes and in another post you mentioned dry pavement. Definately not dry pavement there. Did you use a soap/water mix? BTW, nice 1-wheel peel. You might want to see if you can glue some of that rubber back onto your tire![Biggrinjester](https://themustangsource.com/forums/images/smilies/biggrinjester.gif)
ahhh, nothing like a good burnout. even if it is a one wheel wonder. THANKS MAN!!!! bleach, liquid soap, oil, they all work really good if you cant get that back tire to break loose.
next time in the integra, dont hold it to the floor for like 10 seconds before dumping the clutch. just rev it up and dump it. also i like to pull the e-brake after i drop the clutch in a front wheel drive car. you will sit there still, and its a lot more smoke and much more fun. just dont drag the back wheels. leaves flat spots in the tires. i know. lol
Originally posted by Jigs@May 3, 2005, 12:12 AM
HAHAHA whats with all the Legend lime's??? Thanks.
