BMR k member and a arms
Old Sep 24, 2015 | 07:50 AM
Airborne42's Avatar
I just installed the BMR k member and moving on the the BMR a arms, I have been having trouble getting the front bushings to fit in the k member bracket. I managed to get the passenger side in but the driver side won't go. I am thinking that the driver side bracket is slightly bent in and needs to be banged with a mallet. Has anyone else had trouble with this setup?
Old Sep 24, 2015 | 09:44 PM
Osiris's Avatar
Mine went right in. Try freezing it first?
Old Sep 25, 2015 | 11:22 AM
07 Boss's Avatar
I did mine without any issues. I also assembles everything before lifting it into place. Just thought is was a much easier way to do it.
Did you lube up the bushing before trying to install it? You may have caused the bushing to expand a little bit. It's gotta be a three piece bushing. Try and put the bolt through just the bushing and tighten it down with a couple of washers and see if it compresses at all. if it's the metal sleeve that is preventing it from going in the bracket may be bent or the sleeve is too long. BMR tolerances are quite small and if it is off by the smallest of margins it may be a tight fit. have you measured the brackets on both sides to wee if there is a difference?
Old Sep 25, 2015 | 03:59 PM
Airborne42's Avatar
I managed to get it in after banging the bracket with a mallet a little, it was still a super tight fit. The a arm cross brace bracket also needed to be bent a hair. I'm assuming because the motor mounts also alot smaller, some vibration when starting the car is normal?
Old Sep 25, 2015 | 05:14 PM
07 Boss's Avatar
If you went from the stock hydro mounts to this, yes there is going to be a huge difference in how it feels vibration wise. I went from Prothane bullet mounts so the difference was barely noticeable, maybe a couple of dash board rattles that I didn't have before.
My car is super loud so I didn't notice any other increases in NVH. It is definitely more solid and with that you may get a couple of harsher bangs if you were to hit a pot hole or something along those lines. But you will surely notice a huge difference in the way it feels and handles.
boz
Oct 1, 2015 04:47 PM
oneeyedgiant
Sep 29, 2015 01:33 PM
Ray11
Sep 25, 2015 12:43 PM
GrabberBlue310
2012-2013 BOSS 302
Sep 17, 2015 08:21 AM
