battery drain
Old 1/23/17, 05:26 AM
dancorneliu79@yahoo.com's Avatar
battery drain
Hello, i ve noticed a problem on my car !!
If i dont start the car every 3,4 day the battery is drained all the way. Nothing , no power it all. I just replaced the battery and still the same problem. I ve read the internet and some other owners have the same problem but nobody gave any soultion, except using a charger all the time.
HAVE ANYBODY A SOLUTION ON THIS !
THANK YOU !!
2008 gt , manual, shaker 1000 (dont work ).
Old 1/23/17, 07:01 AM
Buckshot Barry's Avatar
Here is what I use with the Cigarette Lighter Adapter
Old 1/23/17, 02:45 PM
karman's Avatar
Pull the fuses for the shaker
The shaker drawing random power is very common.
If it isn't working, pull all the fuses related to it.
Old 1/23/17, 04:03 PM
Bert's Avatar
Received 1,540 Likes on 1,054 Posts
Probably the Shaker issue that Gravydog described, or a weak battery.
One step short of pulling the fuse is to make sure you turn off the radio before you shut off the car. This will help in some cases.
These cars do have a small drain (miliamps) all the time and they will kill a weak battery.
I had exactly the problem you described; had my battery tested and it tested OK . . . had the system checked by local shop and they confirmed the very low draw, within spec . . . replaced the battery with a new one, and it is fine now. I can leave it sitting for at least two weeks and it still fires right up.
Old 1/23/17, 05:55 PM
m05fastbackGT's Avatar
Received 2,157 Likes on 1,734 Posts
This topic has been beaten to death time and time again.. Consider using the search function, as you'll find very valuable info about this topic addressed in previous threads..
Old 1/30/17, 06:30 PM
don-ohio's Avatar
I'll tell ya...... these modern cars.......they frustrate me with things like this.
I just got back from vacation for almost 2 weeks. Because of being aware that these machines DO draw on a battery, before I left I uncovered the car and started the engine and let my 05 v6 charge up the battery fully by idling for about a half hour.
We really shouldn't have to be worried about stuff like this.
On my 2004 Lincoln LS, I charged up the battery and DISCONNECTED the cable before I left,because IT has even MORE draw than the mustang, with its heated windshield where wipers sit and who knows what else.
I don't like it. don-ohio (:^)
Old 1/30/17, 08:17 PM
As previously mentioned, using the search function will provide all the answers and info you're looking for.. As this topic has been discussed in previous threads time and time again on this forum !
Old 1/30/17, 09:28 PM
don-ohio's Avatar
Okay,I'll try a search on this forum soon. don-ohio
Old 1/30/17, 09:48 PM
You'll find lots of them, believe me
Old 1/30/17, 10:12 PM
don-ohio's Avatar
Reminds me of the Lincoln LS
The LS needs the Ford alternator, and seems to work way better with it. The reason is the PCM has a lot to do with it. DON'T know if this is true of the Mustangs,but sounds feasible.
Well,I searched...........I guess I better break that new Battery tender out of the package! Thanks, m05! don-ohio (:^)
Old 1/31/17, 06:31 PM
Anytime Don !
-Rocky
Old 2/2/17, 08:14 PM
houtex's Avatar
Late, but I figured maybe I'd post this in case it helped out OP, or anyone else.
https://themustangsource.com/forums/...458833/index4/
Look for my post, #70, in that thread. That describes what I feel is needed to help solve the issue. It's been about 4 years since I did all that mess, and *all* my charging/battery issues have gone away. Terminals look the same as when I did all that, and I've not done *one* thing to it since.
I forgot to mention in that post: Your battery can drain itself by being shorted out across the terminals. Dirty battery, acid vapors, and the current just flows between them. This causes the alternator to work harder as the battery slowly dies off, and then you're replacing both.
The washers and dielectric grease will prevent contamination from being a problem, but only if you slather it all over them terminals as I describe. The rest was an exercise in getting the entire area cleaned of any acid/corrosion/contamination, because one of those batteries vapors ate my firewall paint, dammit. :/ BBQ paint happened, and I will do the whole engine compartment one day, it looks pretty good still.
Anyway. If it helps. The CD thing would definitely do it too, as would any active electrical thing in the car.
Old 2/2/17, 08:30 PM
I was also a contributor in that thread nearly 10 years ago in addition to several others as well lol.
Old 2/3/17, 01:01 AM
Yeah ! And if everybody used the search function like they should be doing in the first place, they would know that mostly everybody on this site has known about the battery and CD issues for well over 10 years
Old 2/3/17, 03:58 PM
The point is, you've been a member on this site for well over 2 years now, so start showing it by using some common sense.. You're not a newbie anymore !
Old 2/6/17, 01:09 AM
I pulled out the shaker 1000 for repair and the problem is gone !!
Now, i like the look with original equipment (shaker 1000) and i really hope can be repaired. Radio works fine but cd unit is not working.
If the unit can be repaired am i still gonna have draining issues ?
I bought the car like this so i dont know how was it before...
If cant be repaired there is a good aftermarket replacement ?
THANK YOU VERY MUCH !!!
Your help saved me a lot of trouble and money !!
Old 2/6/17, 03:42 AM
Here's the links below to provide answers to your questions.. For future reference, use the search forum function and type in the keywords: dead battery/drained battery in the search forums box.. You'll then see plenty of threads addressing the shaker 500/1000 issues.. If the links don't work for whatever reason, just type in the keywords I mentioned in the search box..
https://themustangsource.com/forums/...archid=5936568
https://themustangsource.com/forums/...archid=5936610
