Auto Shifter Buzz?
Old Jul 24, 2007 | 07:56 AM
LBJay's Avatar
Auto Shifter Buzz?
Thought I would try out here since a search turned up nothing in the warranty section.
I've been trying to track down a buzz that seemed to come from the dash area. It happens sporadically in the morning when the interior is cool and at low RPMs.
I finally traced it down and it's the auto shifter. There is a small amount of play and when I place light pressure on the shifter the buzz will stop.
Has anyone else experienced this? I hate to go to the hassle of taking it to the dealer if it's a simple fix that somebody has already found.
Old Jul 24, 2007 | 03:15 PM
06GT4RAD's Avatar
It's the trim ring around the shifter. Nothing can be done short of applying some double sided tape which i advise against since if and when it does need to be removed you will most likely break it trying if taped down.
Richard
Old Jul 25, 2007 | 08:08 AM
krnpimpsta's Avatar
How about sticky tak? Or silly putty?
Old Jul 25, 2007 | 08:30 AM
06GT4RAD's Avatar
Good idea.
That would probably work. Not sure how those products react with plastic.
Richard
Old Jul 25, 2007 | 08:34 AM
zaghloul's Avatar
The tak will melt and run if you park in the sun on a hot day. Use tiny quarter inch segments of double sided sticky tape on each corner.
Old Jul 25, 2007 | 08:38 AM
06GT4RAD's Avatar
If you use the double sided tape do not use the Automotive stuff that is black with red backing it sticks really well. Use the household white version it will not be as hard to remove if you need to.
I know mine starts to buzz every now and then and a simple tap with the hand stops it. But i have the Silverhorse Racing Bezel now. But i did the same thing with the stocker
Richard
Old Jul 25, 2007 | 08:44 AM
buy a new trim ring, and boo on the automatics, jk
Old Jul 25, 2007 | 10:18 AM
mvon919's Avatar
i don't think it's trim... check your O/D button... it causes exactly thta BUZZing sound. weird.
Old Jul 25, 2007 | 01:39 PM
jgray5's Avatar
Can you guys show me a picture of what your talking about with the auto shifter buzz.....i think i know what you mean but just to help me thanks.
Old Jul 25, 2007 | 02:06 PM
06GT4RAD's Avatar
It's the trim ring around the outer area of the shifter.
Richard
Old Jul 25, 2007 | 08:10 PM
Northwest GT's Avatar
This might help. It is item number 1.
http://bradbarnett.net/service_man/B...or_Console.pdf
Old Jul 30, 2007 | 08:52 AM
LBJay's Avatar
BINGO! We have a winner.
I had to wait until it was cool enough this morning to get the Buzz again but that's exactly the problem.
I will try to make up a small foam ring to insert and take up the play in the button.
It was difficult to locate because it seemed to come from everywhere and anywhere. I thought I heard it in the center dash, my wife thought it was from her side.
Thanks.
Old Jul 30, 2007 | 04:07 PM
jgray5's Avatar
Really the O/D button is the reason for this.......that would be sweet...ill check that out too next time i hear that **** buzz
Old Jul 30, 2007 | 04:27 PM
davisinla's Avatar
I've got what sounds like a similiar "buzzy" type of noise coming from the same area, but I have a stick and it doesn't seem to be coming from the console. At times it sounds like it might be the mirror, but I think I've pressed everything I can reach without affecting it.
It's driving me nuts.
Old Jul 30, 2007 | 07:26 PM
tdbrown75's Avatar
There is a TSB for this, it's actually a loose exaust clamp that makes the buzz. The TSB reads "vibration noice in the center stack" or somthing similar.
Tim
Old Jul 30, 2007 | 07:56 PM
davisinla's Avatar
Tim
Thanks, I'll do a search. But it sure doesn't sound like it's coming from "under" the car. How can it be an exhaust clamp?
EDIT: Just found the TSB - it indicates 2005 & 2006, so I'm not sure if mine is covered.
It's more of a "buzz" (as described by LBJay) than a rattle.
Old Aug 15, 2007 | 07:18 PM
RUgoinUp?'s Avatar
Davisinla, can you pass along the TBS link or info please? Thanks!
Old Aug 16, 2007 | 08:20 AM
davisinla's Avatar
I think this is it:
http://bradbarnett.net/mustangs/gala...sb06_04_01.pdf
After a bit of reading, I think one of my noises is coming from the shift boot. The last time I heard it, I started grabbing it and the noise seemed to go away. It's kind of hard to tell. I'll be doing some more experimenting.
Old Aug 16, 2007 | 09:59 AM
kevinb120's Avatar
Use double sided tape to cushion the area, but don't remove 1/2 the backing.
Old Aug 16, 2007 | 01:16 PM
metroplex's Avatar
The manual shifter boots tend to vibrate/rub just as easily.
