After 15 years & 62,000 miles I finally replaced the spark plugs
My mechanic carefully removed my Shaker (which involved quite a bit) and replaced my original spark plugs. He said it was time (despite the mostly highway miles) and none of them broke off. He has experienced this before, and was prepared for it, but no problems. They were replaced with the same Ford Motorcraft Platinum plugs so I should be good to go for another long stretch.
I enclosed some photos. It's about what I would expect and definitely time for 'fresh'.
The following 2 users liked this post by NC14GT:
m05fastbackGT (2/18/22),
tbear853 (4/19/22)
NC14GT (2/18/22)
NC14GT (2/18/22)
NC14GT (2/18/22)
No idea guys on the installation. I did not ask. I seriously doubt I will own this car in 15 tears. I'm saving up for a new Mustang already and hope to be in one within a few years, if they still keep making V8 engines of course. Maybe I will keep my current ride if V8's go away. I'll worry about the plugs then if I'm still around at 82 years old. If I am, I hope I can still use the clutch. Knees are starting to get old already.
m05fastbackGT (2/19/22)
Supposedly the next gen S650 models will still include the Coyote 5.0 V8s, but rumor has it the upcoming S650s will also be the last Mustang to be had with a V8.. Unfortunately, it appears production of the V8 engine is gradually coming to an end
NC14GT (2/20/22)
Zero issues. The car runs great and has from Day 1 off the dealer lot. The rust is an unknown unless caused by ethanol in the fuel, or fuel additives?? I'm guessing but my mechanic wasn't concerned. He had no trouble getting them out. Maybe it's just the age of the 15 year old originals.
The rust is an unknown unless caused by ethanol in the fuel.
This is where the anti-seize would help greatly, and why Ford says to do it in the TSB. To prevent those things from either carbon welding or rust welding and breaking off when you try to get them out.
Thanks for comin' to my tex talk.
In addition to applying high temp, nickel anti-seize, running Sta-Bil 360 every tank fill is also effective in preventing rust caused by ethanol in the fuel.
Yup, it's the ethanol. It's a water attractant and it will get in the cylinders and there you go. Also, letting the car sit up and not run is not helping. 62,000 over 15 years is only 4100ish miles a year. 340 miles a month. 12 miles a day. Which I can bet it's not getting driven daily. So it rusts up. Run that car more!
The car sits a LOT! Most of those miles are long distance highway miles driven over a 2 -3 week period each year. The last two years there have been no trips. 2020 due to Covid and this past year we took the Trans Am. Maybe 1,000 miles per year are put on locally, that's it. I guess I could use some of the Lucas ethanol treatment on occasion that I have for my T/A. No rust when those plugs came out. I do use HEET about 3 times a year to remove water from the gas tank but perhaps it is not enough. Chevron Techron once per year too, usually the first week of our travels so it won't just sit in the tank. No big deal I guess if I continue the same routine but I always consider better ideas.
The following 3 users liked this post by NC14GT:
The following 2 users liked this post by tbear853:
m05fastbackGT (4/19/22),
NC14GT (4/19/22)
tbear853 (4/19/22)
