4.10's ... What about replacing entire axle?
Old Jul 16, 2007 | 07:22 AM
gkaufman's Avatar
I ran across this for sale on newtakeoff. Its a GT rear axle with 4.10's in it already.
http://www.newtakeoff.com/index.asp?...OD&ProdID=8179
It's 929 dollars. Which is really steep for a set of gears. I was thinking though if you bought the axle all preassembled and setup from Ford I think you would have a better chance of getting the 4.10's without the whining. If you dont like the 4.10's you could always drop your old 3.55 axle back in. Just an idea. I hate that I cant install my own gears. Its like one of the only things I cant do. I was looking originally for a 3.55 axle so I could practice setting up 4.10's in it and still have a backup axle.
Old Jul 16, 2007 | 07:43 AM
RobK's Avatar
Wow, that's a lot of dough. It's not THAT hard to setup a set of gears so they don't whine. It's also not as horribly difficult to setup a set of gears as people think. If you take your time you can do it yourself. You might need to pull it apart a couple of times to get it right, but it's not rocket science. I used to keep the gears on my original carrier and install my new ring gear on a take-off (or new) carrier so it would be a very simple matter to swap in your old set if the mood strikes you. Just keep tabs of how the stock unit was shimmed.
Old Jul 16, 2007 | 09:16 AM
dustindu4's Avatar
9 is not my lucky number.
I don't know if this is from ford or not. It might be a modded 8.8 with low miles. If it is from ford consider it a good deal because I paid around 800 for my gear install (400 labor, 200 gears, 120 install kit, 50 lube) and it made noise from the beginning. Now the thing is junk after racing on it. With this setup you can at least switch back to stock in an hour or two of work.
Old Jul 16, 2007 | 10:33 AM
kevinb120's Avatar
That doesn't seem all that bad. I have no idea where they got it from though
Old Jul 16, 2007 | 01:32 PM
black sunshine's Avatar
What new take-off Mustang GT came with 4:10's????? Are they just packing a take off case with different gears???
Old Jul 16, 2007 | 01:37 PM
kevinb120's Avatar
I don't know either, I would think it would need to be road-tested to see if everything is perfect.
redfirevert06's Avatar
I saw that and was thinking the same thing, but I was looking at the 3.73 rear end they have.
I think it was a couple hundred less than the 4.10 rear end.
Old Jul 16, 2007 | 01:39 PM
kevinb120's Avatar
where does the 3.73 one come from? I am confused I would think you could easilly sell your stock GT 3.55 rear complete to a V6 owner for $500 though.
Old Jul 16, 2007 | 01:56 PM
It was at the Newtakeoff website.
http://newtakeoff.com/index.asp?Page...S&Category=424
I see it's only $40 less than the 4.10's, not a couple hundred.
Unfortunately I have the 3.31 gears (auto).
Old Jul 16, 2007 | 05:16 PM
RobK's Avatar
Since stangs don't come with either 3.73s or 4.10s they're probably swapping the gears themselves which means...who knows if they're setup right or not? I don't really think it's a good deal by the time you factor in shipping and your time to swap axles.
samjluck
Sep 17, 2015 10:24 PM
Evil_Capri
Sep 11, 2015 08:39 AM
Sep 10, 2015 12:44 PM
GMAYS
Sep 10, 2015 06:19 AM
