24/40mm offset wheels
Old Mar 28, 2010 | 08:41 PM
colbymh's Avatar
Someone remind me again which is which. 24mm offset sticks out further than 40mm or other way around?
I'm ordering up 20" razors tomorrow and want to be sure of how I want it to look.
I want the rear to sit out a tad bit further than the front for a lil offset. Does anyone have an idea how much more it will sit out with the diff offset front to rear?
Old Mar 28, 2010 | 08:46 PM
cubican's Avatar
I have 24mm and love them ,they are the best fitment ever on the mustang. my car is droped 2" and no problems at all.
Old Mar 28, 2010 | 09:00 PM
07S197's Avatar
Swamp Donkey Man Cans
Take a look here for some Ideas.
This is also a good link that will give you an idea of how changing the offset will make the wheel look different.
Old Mar 28, 2010 | 10:25 PM
colbymh's Avatar
I do realize that was my thread, but I was never 100% satisfied that anyone really knew which made them stick in or out..(ie, the 24 or 40mm offset). lol..
Thanks for the other link though..very good.
Old Mar 28, 2010 | 10:57 PM
TTS197's Avatar
The 24mm offset is the one that will stick out and 40mm is tucked in..
Old Mar 28, 2010 | 11:08 PM
colbymh's Avatar
Thank You. Was confused given the spacing is more on the 40mm.
Old Mar 29, 2010 | 04:03 AM
Deric's Avatar
GPSstang06 posted about both offsets of razors on his car (24mm in the rear and 40mm in the front).
https://themustangsource.com/showthread.php?t=465436
Old Mar 29, 2010 | 06:46 AM
colbymh's Avatar
What size wheel are u running? 9, 10?
Old Mar 29, 2010 | 07:18 AM
WaltM's Avatar
Steeda, Saleen Rousch and Shelby all run about a 45mm offset. 24mm offset is right for an SN95.
Old Mar 29, 2010 | 07:19 AM
MaverickMLFD371's Avatar
24MM stick out a tiny bit, 40MM sit tucked under the fender
Old Mar 29, 2010 | 09:02 AM
07S197's Avatar
Sorry, I didn't even notice that was your post. I wasn't trying to be a Smart A$$.
The 24mm offset will give the rim more of a "Deep Dish" look and push the tire out closer to the edge of the fender. The 40mm offset will pull the tire in closer to the center of the car. I would only be worried if your car is lowered that the 40mm offset could rub the outer fender. But that all depends on how "lowered" your car is.
Good luck with the purchase the Razors look great on these cars.
Old Mar 29, 2010 | 12:45 PM
Twin Turbo's Avatar
Thumbs up
Mine are +24mm and, to reiterate what the other guys have said, yes that pushes them right out to the edge of the wheelarch. Mine's lowered on FRRP springs and I have no issues
Old Mar 30, 2010 | 12:06 AM
TTS197's Avatar
What's the width of the wheels that you are looking to run?
Only if you go with a 305 tire or wider on a wheel that has 40mm offset, there's more clearance with a 40mm offset than the 24mm. one will be limited to the tire size that could be used with a 24mm offset since the wheel will stick out closer to the fender.
Nice and Clean Paul.
Old Mar 30, 2010 | 09:11 AM
colbymh's Avatar
lol, I thought it was funny actually. But no I didnt think u meant anything from it. Thanks for all the info.
Old Mar 30, 2010 | 09:16 AM
colbymh's Avatar
Thanks guys for all the info. Will be getting em tossed on tomorrow. Appreciate all the pics, etc. I went w the 24mm offset in rear and 40mm in front w 275 all around. Wont be able to rotate but I can always have the tires torn down and swapped front to rear if the rears get low on rubber.
DarrenGT
Apr 2, 2020 11:52 AM
JonathonK
Sep 24, 2015 06:31 PM
Steve@CJPP
Sep 15, 2015 06:20 AM
