2009 backup camera install
What wires do I need to tie into for the power and the backup signal when I put it into reverse ? I will be doing a wired one , I plan on routing the wires through the inside to the trunk and through one of the grommets to the tag area .
I bought the Pyle brand back up camera off of Amazon. It is great super clear picture and does great at night. I ran the power to the reverse lights and then the A/V cord thru trunk under seats. The only place you can see the wire(which you can't see cause of the lip of seat) is gap from middle of back seat to under the center console. From center console it run around shifter to behind right side inner kick panels and plugs into the radio plug for back up camera. The radio is a kenwood, it was 275 at best buy.
Your welcome it was very simple to hookup only problem is on that radio you have to put car in reverse and press the A/V button on radio face for the camera to come up on screen it isn't like factory that auto turns to camera when put in reverse. But isn't a problem at all. I only use mine in parking lots to get that angle to see around bigger trucks and suvs that I can't see around.
