2006 GT: Rotten Eggs/Sulfur smell?
Old Mar 29, 2016 | 09:26 PM
seaclam's Avatar
I just noticed this tonight while heading back from the restaurant. A rotten eggs/sulfur smell coming from either under the car or the exhaust. I'm going to check tomorrow in the daylight, but I did recently(three days ago) get my oil changed at Jiffy Lube using the Castrol Ultra synthetic 5/30. I also had them change out the fuel filter. They did put in some sort of fuel additive as well. So, I'm wondering if that could be it. Also, they put in that additive when I was at half a tank and now I'm at a quarter and noticing this smell. I've read posts saying it could possibly be a bad CAT, but I just wanted to get some opinions. The car seems to run as great as it always has and the idle is as smooth as ever. No temperature issues either. Oil pressure is solid as always. Anyhow, your thoughts are appreciated. Thanks......
Old Mar 29, 2016 | 09:36 PM
Were you driving it hard? Clutch and/or cats give off a burnt rotten egg smell when subject to extreme heat.
Old Mar 29, 2016 | 10:13 PM
Jazzman442's Avatar
You either got a bad tank of gas or your cats need to be replaced. Some fuel additives will destroy a Cat. We use to Own a gas station for many years we saw this a lot. Run another tank of gas and see.
Old Mar 30, 2016 | 06:31 AM
stupidgenius36's Avatar
Just Plain Rude!
I'm just gonna throw this out there...you say you were heading back from a restaurant. Were you or your wife/other just gassy and lettin' em rip?
Old Mar 30, 2016 | 09:05 AM
NC14GT's Avatar
Most additives nowadays are perfectly safe for converters. The fact that your gas was half full should not matter. When I had an older air cooled 911 my Porsche mechanic told me not to add gas to the 1/4 tank I had in the car (it was the powerful BG additive brand too). It caused no harm and worked well in 'cleaning' everything. Although it seems like a coincidence I suspect the cats are simply bad but I would also take Jazzman442's advice and run another full tank of gas through to make sure. Best of luck.
Old Mar 30, 2016 | 03:54 PM
m05fastbackGT's Avatar
Old Mar 30, 2016 | 04:06 PM
More than likely the rotten egg/sulfur smell came from the restaurant and lingered for awhile before it finally went away
But seriously, I'll just throw this out there anyhow.. So when was the last time you changed your cabin filter ? As a dirty filter just might be a possibility as well
Old Mar 31, 2016 | 12:12 PM
goldenpony's Avatar
You might try some catalytic converter cleaner. Add to gas.
Old Apr 5, 2016 | 04:20 PM
That's an actual product?
Old Apr 5, 2016 | 06:45 PM
kd4gij's Avatar
You didn't happen to take up 2 parking spaces at the restaurant did you? Just sayin.
Old Apr 6, 2016 | 10:08 AM
goldenpony's Avatar
Yup. Check your local Auto Zone or Advance. They should have it .
Old Apr 6, 2016 | 07:05 PM
Great I'll look for it. My DD has that smell and I was told it was the catalytic converters.
eaglebuc1020
1994-2004 V-6
Jul 8, 2018 09:07 AM
I-70 west
05-09 Exterior Modifications
Jan 19, 2017 08:24 PM
5.M0NSTER
36
Nov 20, 2016 03:50 PM
Joeywhat
Tire and Wheel Tech
19
Apr 21, 2016 06:46 PM
