1st Oil Change today @ 1,200 miles....
Old 12/27/04, 07:11 PM
Giddyup's Avatar
Wow, I didn't realize that this puppy holds 7 quarts with filter...... More than I'm used to, and 5-20 is a weight I've never used before as well. I've always been a 10-30 guy, but they told me that this engine with all it's precise clearances needs the thinner 5-20. Oh well, I'm not a wrench head, so I will do what they say.....along with the owners manual and printing on the filler cap.
Old 12/27/04, 07:16 PM
Kellarina's Avatar
Got mine changed around 1,200 also.
Old 12/27/04, 07:26 PM
GTJeff's Avatar
Why 7 quarts. Doesn't owners manual say 6 ?
Old 12/27/04, 07:28 PM
Maverick128's Avatar
One for his homies.
Old 12/27/04, 08:56 PM
Giddyup's Avatar
I dunno..... I heard somewhere that what the owners manual reads is actually somewhere between 1/2 quart and a full quart low. I'll assume that the service techs know best. B) I did question the receipt showing 7 quarts, and they said that is what the 4.6 calls for. I guess it's 6 in the engine and 1 in the filter???
Old 12/27/04, 09:20 PM
nynvolt's Avatar
Holds more oil because of the variable valve thing (just like some VTEC aplications in Honda's) Something to do with oil pressure to actuate the cam shift from 2 valve to 3.
The 5-20 is because it gives an ever so slight MPG boost, all auto manufactuers are doing this now. In mass it makes enough of a differance that they get less penalty for gas guzzler cars.
Old 12/27/04, 10:16 PM
os121's Avatar
I kind of have a question for Brad, or for someone at Ford. Is there any way that we could get official confirmation from Ford on what the oil fill capacity is for the 2005 4.6L V8 engine (with filter) ? It seems strange that the manual would say one thing, and that the dealer techs would say another.
Old 12/28/04, 08:05 AM
GTJeff's Avatar
Did a Ford Dealer do the oil change or a Jiffy Lube etc ?
Old 12/28/04, 08:22 AM
426H's Avatar
Is it necessary to do a oilchange that early? Dont't they break in the engines and make the first oilchange at the factory?
Old 12/28/04, 08:24 AM
holderca1's Avatar
The Mustang spec sheet says 6 qts for the engine, and half quart for the filter.
Old 12/28/04, 08:27 AM
os121's Avatar
Do you have a link to that spec sheet ? Thanks B)
Old 12/28/04, 08:28 AM
Just noticed that you just got your Mustang holderca1. Congrats.
Old 12/28/04, 08:35 AM
os121's Avatar
This is going to be a real mystery. Here is a clip from the 2nd Printing of the 2005 Mustang Owners Guide:
Old 12/28/04, 08:37 AM
holderca1's Avatar
Originally posted by os121+December 28, 2004, 9:30 AM--></div><table border='0' align='center' width='95%' cellpadding='3' cellspacing='1'><tr><td>QUOTE (os121 @ December 28, 2004, 9:30 AM)</td></tr><tr><td id='QUOTE'> <!--QuoteBegin-holderca1@December 28, 2004, 10:27 AM
Do you have a link to that spec sheet ? Thanks B) [/b][/quote]
http://www.fordvehicles.com/assets/p...tang_specs.pdf
That should do it.
Thanks, they delivered it to my apartment at about 8:30 last night. All the waiting was definitely worth it.
Old 12/28/04, 08:49 AM
os121's Avatar
holderca1 - thanks for that document ! It is really neat, and it is the most complete set of specs that I have seen on this car. How did you find it ? Also, I don't want to stir things up, but after looking at it, my take on the oil capacity is 6 qts full, and it is less 0.5qts for the filter, or 5.5qts without the filter.
Old 12/28/04, 08:56 AM
holderca1's Avatar
Yeah I was confused by that as well, but if you look under the V6 column it says add one quart for filter, not sure why they would do it different under the GT column. Also if you look over to the left, it say capacity less the filter, So I would imagine that is the capicty without the filter, but who knows, I will just take it to Ford to change the oil, that way I won't have to worry about messing it up myself. I found when I was looking around on the Ford site.
Old 12/28/04, 09:25 AM
os121's Avatar
Oh ya - I see what you mean. I did not notice the writing on the left. Man - this is confusing. Your approach of using Ford is a good one. If you can, let us know how much oil they added. BTW - great find !
Old 12/28/04, 12:18 PM
Mellow Yellow's Avatar
Changed my oil last week myself, and it took only 6 quarts with a new filter. I filled it to the middle of the XXX's on the oil dipstick, I remembered reading a thread about how the extra notch higher up on the dipstick was not the top fill point, but the top of the xxx's was. I also thought I remembered reading about how overfilling your engine with oil is bad, so I wanted to make sure I didnt do that.
Old 12/28/04, 12:21 PM
holderca1's Avatar
Too much oil is bad, took my car in for service one time, they put too much in, some of my seals started leaking from too much oil pressure.
Old 12/28/04, 12:36 PM
TomServo92's Avatar
Originally posted by Giddyup+December 27, 2004, 9:59 PM--></div><table border='0' align='center' width='95%' cellpadding='3' cellspacing='1'><tr><td>QUOTE (Giddyup @ December 27, 2004, 9:59 PM)</td></tr><tr><td id='QUOTE'> <!--QuoteBegin-GTJeff@December 27, 2004, 6:29 PM
I dunno..... I heard somewhere that what the owners manual reads is actually somewhere between 1/2 quart and a full quart low. I'll assume that the service techs know best. B) I did question the receipt showing 7 quarts, and they said that is what the 4.6 calls for. I guess it's 6 in the engine and 1 in the filter??? [/b][/quote]
You might want to check the level on the dipstick. They may have over-filled it.
Quick Reply: 1st Oil Change today @ 1,200 miles....
