15% off gauge pod with purchase of Aeroforce Interceptor Gauge
Old Sep 26, 2011 | 01:09 PM
BRENSPEED's Avatar
Phone Orders Only (574.594.9559). Purchase an Aeroforce Interceptor Gauge found on www.brenspeed.com and choose any of our many gauge pods for 15% off. Speed Of Sound gauge pods also included!
CLICK TO VIEW AEROFORCE INTERCEPTOR GAUGES
If you are not familier with Aeroforce gauges they just plug into your OBD2 port not only to make your install easy but it is capable of monitoring over 100 parameters!
BLUE LED - Aeroforce Interceptor Gauge
CLICK TO VISIT BRENSPEED.COM AND CHECK OUT THIS GAUGE
The Aeroforce Interceptor Gauge is the most unique gauge we have seen on the market. It uses the OBD2 port from the engine computer to feed data to the gauge. The result is nothing short of remarkable in the amount of data that can be monitored. You can also add a MAP sensor kit to monitor Boost, or add a Wide Band Air Fuel sensor Kit to monitor your air/fuel ratio.
The gauges come with a white and a black face plate, you have the option of using either one.
The Interceptor scan gauge is capable of displaying over 100 parameters, two at a time (8 using cyclic scan), at an adjustable rate of up to approximately 20 times per second. Not all are supported by every vehicle, so there is no guarantee that the Interceptor will display all of these on your particular car or truck. If the vehicle is broadcasting the parameter, the Interceptor will recognize this and make it available for display.
After reading the description below click on the PRODUCT FEATURES tab above for a description of what the gauge can display.
Gauge Information
The Interceptor gauge is 52mm (2 1/16") in diameter and will fit in all standard gauge pods of this size. A 9' cable is included with appropriate OBD2 connector. A splitter cable is included with the dual Interceptor units. The gauge comes configured with a black face and bezel but a polished aluminum silver bezel and white face are included.
A function menu is available by pushing both buttons simultaneously. One menu option allows you to enter a record mode. Once selected, the Interceptor will return to normal scan mode, but will start recording the displayed data automatically when the throttle exceeds 60%. Approximately 60 seconds of data will be stored. Returning to the menu screen, you can choose to replay the stored data on the Interceptor display.
The gauge displays 2 parameters at a time, but can be programmed to cycle through up to 8 parameters during a user determined period of time. This way you can monitor several items without taking any other actions.
Has high intensity warning lights that can be set using a 1 or 2 parameter algorithm. P1, P1 or P2, P1 and P2. For example, trigger the lights when rpm exceeds 6000 rpm, or when trans temp exceeds 230 F and coolant exceeds 210 F, or when air fuel ratio is above 12.5 and throttle is above 75%. Due to the gauges extremely fast update rate, this light is very accurate and easy to set. Once you try it you'll find you can't live without it!
Another menu option offers the ability to swap the foreground and backround colors of the display (as pictured below). Using this feature, for example, the gauge with a black backround and blue characters (negative image) becomes a blue backround with black characters (positive image). Not only can this be visually appealing but beneficial in changing lighting conditions. Positive images are easier to read in bright sunlight, negative at night.
The Interceptor's scan rate can also be adjusted through a menu function.
DTC's (Diagnostic Trouble Codes) can be accessed and cleared via menu options.This essential feature will help the gauge to pay for itself the first time the check engine light comes on. Those that have modified their vehicle will find this very handy when a sensor, vacuum line, etc. has been inadvertently left disconnected, or something was just not put back together properly.
The two analog inputs can be configured through menu choices. A linear conversion can be entered so that an analog signal connected to the gauge can be read in appropriate units. These inputs are handy for pressure signals such as those from MAP and oil pressure sensors, analog outputs from Air/Fuel ratio kits, etc. These signal can then be read and recorded along side the other parameters obtained on the vehicle's bus.
New optional relay output module allows you to control a 12v relay based on values of OBD2 or analog input data.
Last but not least, the Interceptor will measure 0-60 times, as well as 1/8 and 1/4 mile time and speeds. This is accomplished through a simple menu selection. This function is not available on the ISO based due to slower bus speeds.
Installation in most cases is accomplished by simply plugging the supplied connector into the OBD2 port below the steering wheel. Literally plug-and-play!
Dual Interceptor Option: Two Interceptors can be purchased with a special splitter cable that allows both gauges to operate simultaneously. The second gauge of a dual set in most cases is simply another single gauge programmed to working in tandem. This second gauge will not have a performance timer.
Warranty Aeroforce Technology warrants this product and its accessories against defects in material and workmanship for a period of 1 year from the date of purchase.
mlcinema
Oct 7, 2015 10:05 AM
MustangConvert11
Sep 30, 2015 08:01 PM
GLOCKer
Sep 28, 2015 05:20 PM
