06 Manual Tranny
Old Nov 29, 2005 | 04:11 PM
PonyLover's Avatar
Can those of you with a 06 manual tranny's help me out?
Not sure if I have a problem or if it is normal.
My manual when shifted into fourth gear makes a rattling/vibration noice while still increasing speed once it levels out it's fine.
Are any other people experiencing this?
The other gears make no noice at all, it's fourth gear that makes it.
Also I am having a terrible time getting it to go into reverse at times, more often than not.
I know some with 05's were having a issue, but I thought it was to be fixed with the 06's.
I have tried going through all the gears to get it to go into reverse and it does not work. I've tried letting it roll a little when can and that does not work either.
Maybe I should chalk it up to being new for now, maybe break it in some. It only has about 800 miles right now, but will be stored until spring.
Any others with this?
Old Nov 29, 2005 | 04:19 PM
Scott's Avatar
I haven't noticed any noise from mine. As far as reverse goes, you have to start from left of center to get into reverse, ie go from the 1st or 2nd gear position into reverse. This is to prevent you from inadvertantly going into revese from 5th gear... oops, or hitting reverse when you really don't want to.
Hope that helps .
Scott
Old Nov 29, 2005 | 04:47 PM
PonyLover's Avatar
I've tried that, going from first or second to reverse, it did not work.
It's about to be stored for the winter, guess I'll just wait until spring and get more miles on her then see if it still does it, if so will take her in to be looked at.
Old Nov 29, 2005 | 04:52 PM
Paris MkVI's Avatar
Mine is as smooth as a hyperactive greased ferret in a plastic tube factory.
Old Nov 29, 2005 | 04:53 PM
Shifty's Avatar
I think you're shifting into fourth too early and you're lugging it.
Old Nov 29, 2005 | 05:07 PM
PonyLover's Avatar
I've tried it at various speeds, anywhere from 35 to 55 mph, got same noise no matter what speed.
The noise was there until I leveled out my speed then it went away.
Old Nov 29, 2005 | 05:23 PM
dustindu4's Avatar
9 is not my lucky number.
You shouldn't be in 4th gear between 35 and 55. Well you can, if you were just coasting. Downshift man, downshift. You bogging your engine out. There is nothing wrong with your car.
When accelerating, I don't hit 4th gear until 80-85 MPH.
Old Nov 29, 2005 | 07:25 PM
silverGTvert's Avatar
Old Nov 29, 2005 | 07:44 PM
1 COBRA's Avatar
Or at low RPMs
Old Nov 29, 2005 | 07:55 PM
WERKED 66's Avatar
i`m not in 4th unless i am doing atleast 60-65
Old Nov 29, 2005 | 08:12 PM
StangNut's Avatar
Shifting out of 4th and into 5th at 55 is normal for your car in everday, casual driving. Sounds like you have a problem.
A better way to tell if you're shifting too early and lugging it is see what your RPM's are when you up shift.
Old Nov 29, 2005 | 08:16 PM
PolkThug's Avatar
You need to get the reverse gear problem looked at. (and the 4th gear sounds like you are going to 4th too early)
Old Nov 29, 2005 | 08:18 PM
Shifty's Avatar
Originally posted by 1 BULLITT@November 29, 2005, 8:47 PM
Or at low RPMs
That's what lugging it means.
Old Nov 30, 2005 | 07:54 AM
05StangPwnedMe's Avatar
yup, mine too... actually, this is the best feeling manual car Ive ever had...
Old Nov 30, 2005 | 08:40 AM
tw0scoops123's Avatar
You guys need to read the manual. Optimum fuel efficiency says to shift into 4th gear at 30 mph, and 5 at 40. It's not boggin the engine down unless you're racing.
Old Nov 30, 2005 | 09:32 AM
2006GT's Avatar
No problems here... Have it looked at while it's still covered.
Old Nov 30, 2005 | 09:49 AM
desoter's Avatar
Im curious about all this talk about going into 4 "too early".
I have a 15 mile commute to work each day and I rarely get over 45mph durring my trip. I cruse along in 4th with no issues. This engine has more than enuogh torque to handle crusing in 4th at this speed. My 05 tranny makes no odd noises when I cruse to work.
Old Nov 30, 2005 | 10:20 AM
TexaStang's Avatar
5th gear at 40mph?...
Old Nov 30, 2005 | 11:12 AM
PottyScotty's Avatar
My tranny used to be really difficult to get into reverse as well. It eventually loosened up and now goes in pretty smoothly. There will always be times where the gears don't line up and it won't go in, but that is normal behavior.
Old Nov 30, 2005 | 11:16 AM
Paris MkVI's Avatar
I'm usually watching the tach as much as I am the speedo. I generally try to keep the engine above 2K rpm. She responds more enthusiastically. I select my gear accordingly.
Not good for fuel economy. But fuel economy was not on my list when I bought this car.
