Turbo/PCV?
Old May 22, 2013 | 04:15 PM
staakattack's Avatar
Turbo/PCV?
So I'm trying to get some stuff squared away before I start ripping everything apart to throw the turbo in...the tube that goes from the oil feed neck to the intake before the throttle body is part of the pcv correct? How would I reconnect that with the turbo....do I have to add a nipple to the charge pipe?
Old May 22, 2013 | 09:13 PM
bluethunderhorse's Avatar
That hose would need to either be deleted, or moved to the inlet of the turbo.
Old May 22, 2013 | 09:32 PM
texastboneking's Avatar
Bear Eats King...
Bear ****s Bone
I would just add a filter there. Its only there to let pressure out of the crankcase.
Old May 23, 2013 | 04:00 AM
Ok that's what I figured but I kept reading up that if I don't put it back in the intake then it would mess up the a/f ratio...? I don't exactly understand that
