Trying to achieve hp
Old Oct 2, 2013 | 10:02 AM
ArmandoLuna's Avatar
I'm trying to get my 94 gt have get more horsepower, i'm thinking it makes about 185 or 190 to the wheels.
What could I do to bring it up to at least 250?
I have a fender cai installed
bbk pullies waiting to be installed.
planning on getting shorty headers with a xpipe and flowmasters
What kind of other mods would help my goal? It's also my daily driver
Old Oct 2, 2013 | 10:32 AM
all the mods you listed will not add up to much other than to much effort. Save up and get a super charger for it or better yet save up and get a newer car. Sorry but that's what I found ut when I was rebuilding the engine in my 00 gt. Everything I looked in for power adders was just to expensive for the low hp gains I would have ended up with.
Old Oct 2, 2013 | 10:39 AM
Only1Pwny's Avatar
DO A P.I. (Performance Improved) HEAD SWAP ON YOUR CAR!
Changing the heads on ur model with heads from A 99-04 will DRAMATICALLY improve your performance. As a matter of fact I think after a PI swap your engine will actually be BETTER to work on.
I believe this is because you end up with a better compression ratio or something
This and a tune should have been ur first mods lol
Good luck !
Old Oct 2, 2013 | 10:40 AM
Is the 4.6 a better power plant to work with ?
Old Oct 2, 2013 | 10:41 AM
Only1Pwny's Avatar
Btw all the little bolt ons you put on that don't really help u n/a will get u larger hp numbers if you decide to go f/I later on
Old Oct 2, 2013 | 10:47 AM
Only1Pwny's Avatar
It's not necessarily the "best" but is no slouch by any means.
On stock engine internals, you can have up to 400rwhp with a supercharger.
That's if you plan your build carefully and make sure you have all the right supporting mods.
N/a it is a slouch lol. But still a reliable motor
Old Oct 2, 2013 | 10:50 AM
McNassty's Avatar
Get the Trickflow HCI combo and you will make more than 250
Old Oct 2, 2013 | 10:52 AM
Originally Posted by Only1Pwny
DO A P.I. (Performance Improved) HEAD SWAP ON YOUR CAR! Changing the heads on ur model with heads from A 99-04 will DRAMATICALLY improve your performance. As a matter of fact I think after a PI swap your engine will actually be BETTER to work on. I believe this is because you end up with a better compression ratio or something This and a tune should have been ur first mods lol Good luck !
He has a 94. Not a 96.
Old Oct 2, 2013 | 11:07 AM
LivinTheStangLife's Avatar
^this
Old Oct 2, 2013 | 11:28 AM
Only1Pwny's Avatar
That's right does that mean he has the 5.0?
Old Oct 2, 2013 | 11:33 AM
Yep...
Old Oct 2, 2013 | 11:37 AM
Yeah my 5.0 takes off like a potato with a five speed.
Old Oct 2, 2013 | 12:02 PM
Only1Pwny's Avatar
Lmao ur hysterical dude!
And btw sorry for the misinformation. I thought you had the modular 4.6 2v which is what I have.
Old Oct 2, 2013 | 12:04 PM
Only1Pwny's Avatar
I thought 5.0's were fast though?
Old Oct 2, 2013 | 12:08 PM
Eh it's just like any other car on the road, nothing special here.
It's basically a toyota camry in terms of taking off and power wise. I've been reading about how they got 240hp out of the 94 cobra. Wouldn't just putting cast iron heads with a upper and lower I take make 240? Or is their more to it?
Old Oct 3, 2013 | 07:52 AM
A lot of people do the gt40 head swap which is the heads off the 94-95 cobras but if you're gonna do head might as well wake it up better with good flowing aluminum heads. My 95 (which I bought built) has gt40 heads, e303 cam, trick flow upper and lower intake, pulleys and 4.10 gears. Has nitrous hookup but I don't spray it so I bumped timing back up from where they used to spray on it and if I put new tires and a clutch on it I would be running real low 13s possibly touching 12s in the 1/4. Stock 5.0s are very slow but a little work and they will move
Old Oct 3, 2013 | 11:13 AM
if your going to do all that mid as well get some headers as well
Old Oct 3, 2013 | 11:54 AM
Agree! Don't know why the previous owner of my car wouldn't have put long tubes on when they built it bc I would've but oh well. .
Old Oct 3, 2013 | 03:37 PM
Well looks like I have my next mod in mind.
If I get the gt40 heads, I'm going to need a new intake manifold right? Plus wouldn't I need a bigger good for clearance ?
Old Oct 4, 2013 | 12:19 AM
McNassty's Avatar
No, you can run with stock intake and hood, you will just need a tune to make it run efficiently, you can get the intake and still need a tune and prolly injectors and calibrated MAF but the hood is good unless you go intake spacer and other mods
