tracktion control
Old May 9, 2006 | 08:43 AM
99stang's Avatar
tracktion control
Hi, i have a 99 mustang gt and after instaling my shortthrow shifter, my traction control button doesnt work anymore. i was woundering if anyone knows what the fuse is for the traction control.
http://www.cardomain.com/ride/2312583
Old May 9, 2006 | 02:59 PM
J2D's Avatar
J2D
There should be a list in you owners manual that tells you what each fuse is for.
Old May 11, 2006 | 04:51 AM
99stang's Avatar
I thought of that but one problem, when i bought the car it didnt have the cars book. so i might have to do a trial and error unless someone knows. thank u
Old May 11, 2006 | 07:41 AM
tricky02GT's Avatar
You should be able to see just by looking at each fuse.
Old May 11, 2006 | 10:41 AM
99stang's Avatar
would it be one of the 10v fuses or the larger ones?
Old May 11, 2006 | 07:34 PM
TJ4Cam's Avatar
When you took the console apart to do the shifter did you perhaps bump any wiring/plugs? Just another thought??
Old May 11, 2006 | 10:21 PM
tricky02GT's Avatar
Maybe you lost a wire when you took console apart. Does the traction control still activate? Will find my manual and get back to you.
Old May 12, 2006 | 04:59 AM
99stang's Avatar
it still works, when i hit 4,000 rpm it kicks in. it sucks when i want to do a burnout. thanking u for helping me out
Old May 12, 2006 | 07:10 AM
Scothew's Avatar
Stubborn Bear
TMS Staff
Check to make sure you got hte harness plugged back in good to the button. Other than that, just start checking fuses. Im guessing it would be one of the smaller blade fuses.
Old May 12, 2006 | 07:45 AM
Evil_Capri's Avatar
I thought the TC doesn't work past 4K . . . .
Old May 12, 2006 | 08:01 AM
Scothew's Avatar
Stubborn Bear
TMS Staff
It did on a bullitt I drove
Old May 12, 2006 | 08:10 AM
Evil_Capri's Avatar
Huh . . I guess I haven't really tried it on the Mach. I usually turn it off as soon as I start the car.
Old May 12, 2006 | 01:15 PM
99stang's Avatar
if i sit there and rev it to 4 its with not work but then i red line it in 5 seconds or so. im gonna check the wiring then the fuses thanks for the help
Old May 13, 2006 | 11:09 AM
99stang's Avatar
i took off the boot and the wires are fine it might be a short. is there a wire connection that i can take off at the rear axle?
yabutt
Oct 23, 2015 01:05 PM
GrabberBlue310
2012-2013 BOSS 302
Sep 17, 2015 08:21 AM
