spedometer
Old Nov 3, 2012 | 10:26 PM
dj050894's Avatar
spedometer
i bought my mustang about a month ago, 2000 gt. the spedometer shows about 10mph faster than im actually going. does anyone have a solution to fix this?
Old Nov 3, 2012 | 11:50 PM
Getportfolio's Avatar
You will need a diablo sport predator.
On the contrary, My guess is someone already dialed in a code from this unit to accommodate larger wheels or there could be a chip installed already. (Diablo sport, super chips)
Old Nov 4, 2012 | 07:08 AM
dj050894's Avatar
but it has 17'', arent those factory?
Old Nov 4, 2012 | 07:41 AM
shurtual86's Avatar
Yes but previous owner could have had larger rims on (18in+), and put the stock rims back on when he/she sold it to you and didn't retune the speedo.
Old Nov 4, 2012 | 07:42 AM
dj050894's Avatar
thanks guys
Old Nov 4, 2012 | 08:52 AM
Yes. This is pretty likely. If the speedometer was having factory internal problems, you would see other symptoms and errors.
No joke: some 00 GT's came with 16 inch wheels but most came with 17 inch. Even if you just upgraded to and 18 inch wheel, you would throw your speedometer off. (Unlike the new ones) that is why you would need a programmer to correct the speedo.
I would just ask the person you bought it from. He definitely used a programmer on that car.
Old Nov 4, 2012 | 10:51 AM
Dbranham's Avatar
How about rear gears?
Old Nov 4, 2012 | 12:07 PM
Correct. But its not as noticeable depending on ratio.
Plus a gear swap is fairly costly and most people put the money first in exterior mods. Either one will throw the speedo off.
I'd get the predator anyway to redefine/firm shift points and other mods that the OP may want in the future.
The factory tune is loaded in the unit as well.
Old Nov 4, 2012 | 03:12 PM
1999Pony's Avatar
Search for a shop that will calibrate you speedo. It shouldnt cost that much and they can calibrate it correctly.
Old Nov 5, 2012 | 10:28 AM
dj050894's Avatar
i would ask the guy but i bought it from a dealer and they probally wont give me his number lol. i have a mechanic looking at it this weekend so i ask him about it
Old Nov 5, 2012 | 02:44 PM
SteveRob's Avatar
Agree that the dealer is unlikely to give out his number but you could always have them pass your number to him to call you should he wish
Old Nov 11, 2012 | 04:44 PM
dj050894's Avatar
i talked to the mechanic today and he said it would be alot of work because it has an aftermarket transmission in it and he dosent know what gears are in it
Old Nov 11, 2012 | 04:56 PM
Are you positive it's the gears? Can you pop the factory wheels on and then check the speedo?
Sounds like a lot of trouble. Lot easier than digging into your tranny.. Btw who installs an entire aftermarket tranny? The mechanic Sounds a little wavy...
Old Nov 11, 2012 | 07:13 PM
1999Pony's Avatar
Its not going to be the tires that are throwing your speedo off. These cars will calibrate themselves for tires size. I had 15s stock on mine, went to 17s with no change. Even had it calibrated, for an unrelated reason, and it showed that.
More then likely, if its off that much, the previos owner had gears installed and that threw it off. There are ways to check the ratio without have to rip anything out, but you do need to remove the dif cover.
Old Nov 11, 2012 | 08:23 PM
11SHELBYGT500's Avatar
What?! Wheel and tire size does matter, you must keep the same diameter.
Old Nov 11, 2012 | 08:42 PM
Aussie Cobra's Avatar
Diameter is the key regardless of wheel and tyre combinations
Old Nov 11, 2012 | 08:46 PM
How can you say regardless of wheel and tire combination, when those two things make up the diameter? Huh
Old Nov 11, 2012 | 08:47 PM
I have a Diablosport Predator tuner. Well worth the investment. You can also check the gear ratio comparing revolutions of a drive wheel with the driveshaft.
Old Nov 11, 2012 | 08:48 PM
Like I said: diameter is the key!
Old Nov 11, 2012 | 08:49 PM
Respectfully. Nope.
I swapped the stock 17s for 18s on the 01 GT and it instantly threw the speedo off...considerably at that. It took the Predator to dial in a code to compensate. My 00 has had more wheels than I've had shoes. Each time, I had to break out the hand held tuner.
