Shift Kits...
Old Nov 18, 2005 | 10:22 PM
DrunkenDragon713's Avatar
I'm thinking about getting a shift kit in about a year, and I just want to know if it's even worth getting. I've been told with just a shift kit your 1/4 mile time drops nearly 1/2 a second. If this is true, then it's probably worth it...
But, do I have to get the tranny rebuilt?
Also, is there anything better I could do to get about the same results?
Old Nov 19, 2005 | 12:22 PM
Mestizo's Avatar
I thought you had a 5 spd? If so, all you need is a shifter top ones running around $180(Steeda, Pro 5.0, and MGW). I believe UPR makes one that's a little cheaper, depending on budget.
There shouldn't be a need for a tranny rebuild on a 5spd.
Old Nov 19, 2005 | 09:36 PM
Nope, I have an auto, 4speed i believe. WOuld I have to have a tranny rebuilt for an auto though?
Old Nov 19, 2005 | 11:23 PM
Scothew's Avatar
Stubborn Bear
TMS Staff Retired
research the "Jerry Mod" on http://www.tccoa.com. Jerry W. now of SCT worked for ford and designed the valve body in the 4r70w and the jerry mod is a way of making the tranny better. You will want/need a tune as well, I recommend Doug904 of http://www.bamachips.com. Also another great thing for an auto based car is a tranny cooler. Summit racing sells some good kits that come with everything you need.
Old Nov 20, 2005 | 12:17 PM
Price wise, what's better? J Mod or SHift Kit?
Old Nov 20, 2005 | 01:55 PM
Scothew's Avatar
Stubborn Bear
TMS Staff Retired
shift kit is probably cheaper, but I think the j-mod is possibly better. If you can find a shop that will install the j-mod or if you can order a valve body already prepared, that would be the way I would go. I know Dennis Reinhart of http://www.reinhartautomotive.com did alot of cars using the J-mod and they may sell the valve bodies now.
ding fries are done. (my wife wanted to type that)
jim010
Jun 24, 2024 04:23 PM
Gigantor
May 11, 2023 07:31 PM
K.A.I.N
Sep 25, 2015 03:27 PM
