Sequentials
Whats the main diff between the two? I'm looking at the meter kit but i dont want to wire anything up. is the webelec kit just plug n go and no wiring?
The chasers from Meter4IT are excellent! A friend of mine has them in his '05 and another has them in his '99. I will be putting them in my '00 in the very near future. I have contacted the owner on a couple of occasions, as has my friend with the '99, and he's been very helpful. I highly recommend them.
Actually, my friend with the '99 still has the sequentials he took off to install the Meter4IT chasers... he offered them to me for free, but I love the chase so much, I'm going to buy them.
Jerad
so basically there IS splicing a couple wires in the meter4it unless i get the flasher?? is there wiring for that? I've dont a lil of that but not enough for this.
http://www.webelectricproducts.com/
Stop thinking and do it.
The kit from meter4it can be ordered with a modified flasher (which I highly reccomend) this simply replaces the flasher unit that is under the steering console above acc pedal (yellow unit). This saves taking the old one apart and messing around soldering.
*You still need to splice regardless of flasher unit*
There is a small amount of wiring involved either way but it is absolutely no problem with the instructions that come with the kit.
I was a little afraid at first, cutting into all the wires but you only cut 2 wires (if i rem rightly) and the whole process takes about an hour.
As stated earlier in the post, sequentials are great but they suck after you see chase mode. As I have said before this is a great product, wouldnt you agree fellow "chasers"??
If you can cut a wire and squeeze a pair of grips around a piece of plastic then you can install this product.
Really is easy, if it wasnt then I would certainly say so. The scotchlocks supplied just cut into the wire themselves then you slide a connector over the back just like a pen and cover.
If you go ahead and need help feel free to pm me, will gladly talk you through it.
dustindu4
05-09 Exterior Modifications
5/20/05 09:10 PM
