Rotor Ware Help
Old Mar 23, 2014 | 07:26 PM
sglenn87@yahoo.com's Avatar
Rotor Ware Help
Just installed a new set of cross drilled a slotted rotors on my 2002 GT. All went great but for some reason the rear right rotors is getting grinding on the top pilling off the coating and leaving odd heat marking on the very outer edge of the rotor. A mechanic looked at it and grabbed my hub and notice play in it. Was wondering if anyone thinks its just the wheel bearings gone bad or if the caliper might be bad as well. Its only doing it on the rear right. Would like some help with this before my money goes down the drain on my new rotors and pads. thanks
Old Mar 25, 2014 | 04:31 PM
Garbone's Avatar
If the mechanic can "notice" play in the outer bearings, its definately time, and can definately have an affect on how everything is tracking, and aligning.
If things are not spot on, then yes, there can be heat, and wear marks.
Old Mar 25, 2014 | 05:21 PM
Ok thanks. I bought the bearings and seals for both sides. might as well changes both while I have the rear end housing open to change the right side. Also know a step by step on the brake boost change on the 2002 GT (hydraboost) system?
Old Mar 26, 2014 | 11:08 AM
Garbone's Avatar
I dont, sorry.
Start googling and you may be surprised at what you can find online...
Sep 16, 2015 06:44 PM
Joeywhat
Sep 6, 2015 08:09 AM
lowblustang00
Sep 5, 2015 12:18 PM
mrrooney
Jul 26, 2015 09:35 AM
