redoing the MAF
Old Aug 17, 2005 | 03:41 PM
DrunkenDragon713's Avatar
does this cost a lot? b/c i'm looking into buying a cold air intake and throttle body but don't want to spend over 250 total
Old Aug 19, 2005 | 09:47 AM
Scothew's Avatar
Stubborn Bear
TMS Staff Retired
What do you mean by redoing the MAF? if you mean moving it inside hte fender with a CAI, it should cost you anything, unless you have to get some wire and butt connectors to extend the harness.
Old Aug 19, 2005 | 11:27 AM
I was reading on a site and it said that for certain Throttle Body/intake kits that the MAF will have to be recalibrated.
Old Aug 19, 2005 | 11:32 AM
Scothew's Avatar
Stubborn Bear
TMS Staff Retired
No, the only time the MAF has to be recalibrated is if you change fuel injectors. Normally you can still run different injectors and the stock maf, but it has to be corrected through a chip or flash through the computer done by a tunber. a CAI and throttle body should be ok with teh stock MAF in all but supercharged instances.
Old Aug 19, 2005 | 02:03 PM
Cool, thanks for the help man...
Antigini-GT/CS
Oct 5, 2015 09:43 AM
Omegaprime92
1994-2004 V-8
Sep 8, 2015 08:53 AM
mystang14GT/CS
2011 - 2014 GT/CS
Aug 26, 2015 09:48 AM
