Recall Question
Old Nov 20, 2006 | 12:28 PM
redhorse's Avatar
Recall Question
Where, online, can I go to find out if a car has a recall on it?
Does anyone know of a recall on a steering problem on the SN95 model years '99-'04?
Old Nov 20, 2006 | 12:54 PM
shaun_beauchamp's Avatar
Technical Service Bulletins
2003 MUSTANG - US (English)
05-18-7
WIRING - SOLDERING AND CRIMPING REPAIRS - SERVICE TIPS
05-16-11
SAFETY BELT RETRACTION SPEED
05-14-3
SQUEAK/CREAK NOISE FROM STEERING RACK WHEN TURNING
05-9-18
DISCHARGED BATTERY - CHARGING SERVICE TIPS
05-3-10
SAFETY BELT WEB STOP BUTTON SERVICE
04-24-20
LIMITED SLIP AXLE CHATTER, SHUDDER, BINDING SENSATION, OR VIBRATION DURING LOW SPEED TURNING MANEUVERS
04-24-14
GENERAL PCM PROGRAMMING PROCEDURES
04-24-5
REAR WINDOW DEFROSTER GRID/INTEGRAL ANTENNA DIAGNOSIS AND REPAIR - TERMINAL TAB REPAIR
04-24-3
LEATHER-WRAPPED STEERING WHEEL - LEATHER COMING LOOSE
04-21-6
EXHAUST LEAK - CRACKED OR SEPARATED RIGHT SIDE EXHAUST PIPE - 3.8L AND 3.9L ENGINES
04-19-8
MANUAL TRANSMISSION HARD TO SHIFT INTO FIRST/REVERSE FROM A STOP
04-17-4
MALFUNCTION INDICATOR LAMP (MIL) ILLUMINATED - SYSTEM LEAN DIAGNOSTIC TROUBLE CODES (DTC'S) - SERVICE TIPS
04-16-1
ENGINE MISFIRE OR ROUGH RUNNING - COIL ON PLUG (COP) IGNITION SYSTEMS - WDS COP KIT DIAGNOSTIC TIPS
04-15-6
TR3650 MANUAL TRANSMISSION - JUMPS OUT OF GEAR 2ND AND/OR 3RD - CLASH NOISE AND/OR RASPY FEEL ON GEAR ENGAGEMENT
04-13-4
TRANSMISSION RATTLE NOISE OR DIFFICULT TO SHIFT - TREMEC T56 6 SPEED MANUAL
04-5-3
CLIMATE CONTROL - RATTLE NOISE FROM INSTRUMENT PANEL VENTS - DIFFICULT TO ADJUST
NOISE - CLIMATE CONTROL - RATTLE NOISE FROM INSTRUMENT PANEL VENTS - DIFFICULT TO ADJUST
04-1-2
BODY - INTERIOR TRIM - HEADLINER SAGGING IN REAR
03-25-6
ENGINE - ROMEO BUILT 4.6L 2V - TICK NOISE FROM ENGINE - ENGINES BUILT BEFORE 9/17/2003
03-25-5
PAINT - PIN HOLES AND/OR PAINT DELAMINATION ON VEHICLE HOOD - VEHICLES BUILT 6/1/2001 THROUGH 3/1/2003 ONLY
03-24-3
TRANSMISSION - AUTOMATIC TRANSMISSION GEAR SELECTOR LEVER STUCK IN PARK, UNABLE TO SHIFT INTO PARK - OVERDRIVE FUNCTION INOPERATIVE
03-23-2
BODY - MIRROR - EXTERIOR MIRROR GLASS AND MOTOR REPLACEMENT - SERVICE TIPS
03-22-1
BODY - NOISE - HOOD SCOOP (SHAKER) RATTLE NOISE
ENGINE - NOISE - HOOD SCOOP (SHAKER) RATTLE NOISE
03-20-3
DRIVEABILITY - MALFUNCTION INDICATOR LAMP (MIL) ILLUMINATED WITH DTC'S P0442, P0455, P0456, P0457, P1442 OR CHECK FUEL CAP LAMP ILLUMINATED WITH DTC P0457
03-18-1
ELECTRICAL - REMOTE KEYLESS ENTRY (RKE) - SERVICE TIPS
03-14-8
TRANSMISSION - NEW TRANSMISSION COOLER FLUSHER - SERVICE TIPS
03-11-4
ENGINE - MUSTANG COBRA - TICK NOISE FROM ENGINE - COBRA VEHICLES EQUIPPED WITH ENGINES BUILT BEFORE 11/1/2002 ONLY
03-10-1
PAINT - PLASTIC BUMPER/FASCIA PARTS - PREPARATION PROCEDURES - SERVICE TIPS
03-9-5
SUSPENSION - CLUNK OR POP NOISE FROM REAR SUSPENSION - MUSTANG COBRA ONLY - SERVICE TIPS
NOISE - CLUNK OR POP NOISE FROM REAR SUSPENSION - MUSTANG COBRA ONLY - SERVICE TIPS
03-8-3
ENGINE - ENGINE OIL LEVEL INDICATOR MARKINGS - REPORTS OF LOW OIL LEVELS
03-3-6
SUSPENSION - DRIFT OR PULL TO RIGHT OR LEFT - MUSTANG COBRA MODELS ONLY
03-1-5
TRIM - PASSENGER SEAT RUBS AGAINST DOOR PANEL
02-23-7
COOLING SYSTEM - MOTORCRAFT PREMIUM GOLD ENGINE COOLANT - SERVICE TIPS
02-23-3
DRIVEABILITY - FUEL PRESSURE RELIEF VALVE (SCHRADER VALVE) DISCONTINUED
ENGINE - 3.0L/3.8L/4.6L - FUEL PRESSURE RELIEF VALVE (SCHRADER VALVE) DISCONTINUED
02-22-1
DRIVEABILITY - SURGE/ROLLING IDLE - GEAR DRIVEN SYNCHRONIZERS - INCORRECT INSTALLATION - CAMSHAFT POSITION SYNCHRONIZER (CMP) INSTALLATION TOOL CORRECT APPLICATION
ENGINE - GEAR DRIVEN SYNCHRONIZERS - INCORRECT INSTALLATION - CAMSHAFT POSITION SYNCHRONIZER (CMP) INSTALLATION TOOL CORRECT APPLICATION
02-21-13
ENGINE - STRAIGHTEDGE PROCEDURE FOR CHECKING CYLINDER HEAD AND BLOCK FLATNESS
02-20-8
CLIMATE CONTROL - A/C SERVICE TECH TIPS
02-17-8
NOISE - WINDNOISE FROM THE "A" PILLAR AREA
02-17-6
LAMP - BRAKE - INADVERTENT DISABLING OF BRAKE SHIFT INTERLOCK
02-16-7
BODY - PAINT - APPROVED PAINT MATERIALS FOR WARRANTY REPAIRS
Old Nov 20, 2006 | 01:07 PM
CircuitBreaker's Avatar
http://www.alldata.com/recalls/
CNFLCTD
GT350
Aug 4, 2017 07:08 AM
MustangConvert11
Sep 30, 2015 08:01 PM
