Oil additives 96 gt
Old Sep 29, 2012 | 09:37 AM
steelhorse06@hotmail.com's Avatar
Oil additives 96 gt
Does anyone have any suggestions on any kind of additives that might would help slow down oil consumption?
Old Oct 1, 2012 | 10:37 AM
mdelao's Avatar
Is what I've heard, not my experience
Old Oct 1, 2012 | 10:38 AM
mdelao's Avatar
Originally Posted by mdelao
Marvel mistery oil Is what I've heard, not my experience
Correction
Old Oct 1, 2012 | 07:14 PM
does you ride burn oil when you first start it up or when your driving along and you floor it orrrrrrrrr both?? How many miles on the clock?
Old Oct 2, 2012 | 07:11 PM
Its got a 149k on it. It blows a little puff of white smoke on startup and when I start to back out. I dont really notice it any other time.
Old Oct 2, 2012 | 07:15 PM
97GT03SVT's Avatar
How drastic is the oil burn? In my experience with 4.6s they all tend to burn a little oil even when nothing is wrong. I remember my 97gt being slightly low on oil between oil changes since it was virtually new.
Old Oct 2, 2012 | 08:09 PM
I'm gonna guess about a quart every two to two and half weeks.
Old Oct 2, 2012 | 08:26 PM
Dbranham's Avatar
My car burns/leaks about a quart a month I say burn cause well it does and it also chooses to slowly slowly slowly drip. I added some Lucas stop leak for oil treatment stuff and it greatly slowed it done
Old Oct 2, 2012 | 08:30 PM
Dbranham's Avatar
Also what oil are you using? I'm using full synthetic 5w30
Old Oct 3, 2012 | 04:14 AM
I'm using part synthetic 5w30 castrol gtx
Old Oct 3, 2012 | 08:13 AM
valve guide seals are bad if it puffs when you first start it up. no oil additives will help that as far as I know. Theres some stuff out there called restore that is suppose to help with scored cylinders. I have never used it but it might help you with as many miles as you have on your car.
Old Oct 3, 2012 | 08:14 AM
if you have some time do a compression test some day
Old Oct 3, 2012 | 03:30 PM
I'm gonna perform a compression test on it Sunday. Any ideas on what the readings should be?
Old Oct 3, 2012 | 05:09 PM
I think somewhere around 180 or so. The thing is that they are all very close to each other.
Old Oct 4, 2012 | 06:31 PM
So basically if one is way off from the others, there could be a internal problem with that cylinder.
Old Oct 5, 2012 | 07:55 AM
14Glassback
Oct 4, 2015 08:52 AM
Sep 30, 2015 07:02 PM
southern stang
Sep 26, 2015 04:19 PM
Bytor1960
Ecoboost
Sep 25, 2015 09:00 AM
Jailbirdwatcher
Sep 25, 2015 06:39 AM
