New sound system question
Okay I'll check them. And I pulled the wiring diagram from the bag the adaptor came from. An just connected the grounds strait to the ground stub on my battery. My guess is the fuses now.
Bear Eats King...
Bear ****s Bone
Bear ****s Bone
Thanks for the help thus far! I have to step away from the stang for a while and go look at getting a replacement cast for my wrist, but when I get home I'm pulling some fuses!
Bear Eats King...
Bear ****s Bone
Bear ****s Bone
That connector with the RCA cables that you bought is what turns the amps on for the factory unit.(plug should look like this: ) The two blue/white wires give power to the amps, they need to be hooked up to the RADIOs amp wire. Look at the wiring diagram that came with your radio, there should be a wire for power to an amp. That is the wire you need to hook the two blue/white wires too. The pioneer i installed i think it was also a blue/white wire out of the back of the new radio, i think its the same for all pioneer units. I dont have the car in front of me right at the moment, my girlfriend wont be home till tomorrow. The black/white wires are the amp grounds, they need to be ran to chassis ground. i grounded mine out on that metal brace underneath where the radio sits in the dash.
Originally Posted by pity7700
that blue/white wire youre holding up in this picture is the wire that needs to go to the two blue/white wires from the aftermarket plug witht eh two RCAs and ground wires.
