NEED HELP!!
Old Jul 5, 2016 | 01:20 PM
jwilliams41's Avatar
NEED HELP!!
I have an 02 GT and my front passenger side tire wears our almost instantly. i had an alignment done and they pointed out my lower control arm bushings. i replaced them and its still doing the same thing. I also replaced the hub assembly along with the ball joint and tie rod. The tire wears out on the very inside down to the wire while the rest of the tire is still in good shape. any ideas? Thanks in advance.
Old Jul 5, 2016 | 05:08 PM
EF1's Avatar
EF1
Sounds like a toe out problem. Did you have the car re-aligned after replacing the control arm bushings?
Old Jul 5, 2016 | 05:39 PM
Thanks for the reply but the guy that done the alignment said he couldn't fully get it lined up. the bushings wasnt really bad. I will take it back up there sometime this week.
Old Jul 5, 2016 | 07:44 PM
AzPete's Avatar
Has the car been lowered any?
Old Jul 5, 2016 | 09:12 PM
yes it has and it was done before i got it
Old Jul 5, 2016 | 09:18 PM
AzPete's Avatar
Check out different lowering kits on line, they may recommend a type of (I believe) camber plates or kits to allow for more adjustment when a car is lowered.
Old Jul 5, 2016 | 09:38 PM
could i possibly get the lowering plates without buying the whole kit?
Old Jul 6, 2016 | 04:37 AM
TripleBlack14's Avatar
Are you the original owner? If not, how long have you had the car?
If the mechanic says he can't get it aligned, take the car to a reputable auto body shop and have them check for evidence of structural damage that may have been repaired improperly. If there is unibody misalignment no amount of suspension modifications will correct your problem.
Old Jul 6, 2016 | 07:22 AM
AzPete's Avatar
You just have to look and see if you can get just the plates.
Old Aug 26, 2016 | 10:22 PM
LivinTheStangLife's Avatar
get caster camber plates and make sure they know its been lowered and they should be able to align it better. lowering them without caster camber plates will wear the hell out of the inside of the front tires
Old Aug 29, 2016 | 07:53 PM
Absolutely need the plates. The stock 'adjustments' don't go far enough to line up the cars when they've been lowered. A C/C plate kit like the one from Maximum Motorsports is easy to install and helps wonderfully.
Old Aug 30, 2016 | 08:37 AM
Dallas Mustang's Avatar
Check us out. www.Dallasmustang.com
Kotenukimen
'10-14 Exterior Modifications
Jun 22, 2016 11:21 AM
usaf1965
1994-2004 V-8
Jun 7, 2016 07:17 PM
Strick9
Apr 14, 2016 02:13 PM
Evil_Capri
Motorsports
Apr 14, 2016 07:22 AM
