Kenne bell
Old Dec 31, 2011 | 08:35 PM
shaunrc's Avatar
Kenne bell
OK ladies and gents I would love to put a kenne bell supercharger on my 2000 gt from what I understand kenne bell designed their supercharger to work with stock internals of the motor is there anything I should do in addition to the supercharger any suggestions are definitely welcome thanks in advance
Old Jan 1, 2012 | 10:22 AM
cpotts13's Avatar
Bigger brakes.
Old Jan 1, 2012 | 10:33 AM
CCTking's Avatar
Bigger brakes, which also usually means a new set of rims and tires r in order as well. More supportive seats like Sparco's or Recaros, and even though they can run on the stock bottom end i would still try to add some forged and upgraded parts in there just to be safe. Especially if u wanna turn the boost up later down the road
Old Jan 1, 2012 | 11:52 AM
shaunrc's Avatar
OK I was thinking bottom end as well but that's an extra 3000 at best
Old Jan 1, 2012 | 02:51 PM
1999Pony's Avatar
You can get away with a stock bottom end but you'll have to run low boost, no more then 5-6 psi.
Old Jan 1, 2012 | 04:12 PM
bryangb7's Avatar
How much does this kit run?
Old Jan 1, 2012 | 04:24 PM
CCTking's Avatar
If i remember right its a few thousand for everything you need
Old Jan 1, 2012 | 04:39 PM
JDF's Avatar
JDF
I think the 2.6l kit was $6k last I looked. The 2.1 or 1.8 should be cheaper
Old Jan 1, 2012 | 04:41 PM
shaunrc's Avatar
I'm pretty sure everything from kenne bell is 4200 but bottom end kits are about 1200 and if you can't do it yourself its about another 1500 and what the fun in running low boost
Old Jan 1, 2012 | 05:22 PM
1999Pony's Avatar
Rather run low boost then no boost until you can build the motor.
Old Jan 1, 2012 | 07:26 PM
shaunrc's Avatar
True but if you do happen to blow your motor your supercharger is going with it
Old Jan 1, 2012 | 08:18 PM
1999Pony's Avatar
No thats not very likley unless you spit a rod right through the middle of it. If you blow you motor you dont necessarily loose you intake, or heads, or cams. Its very unlikely that an damage would happen were you motor to let go. That being said, the 4.6 are very boost responsive even on stock internals. They can very easily and safely handle upwards of 400hp for years without any issues . You fully build the bottom end then you in the 600-800 hp range and it comes down to what the stock iron block can handle, not the internals.
In the end, its what you feel comfortable with, all im saying is that its very possible to boost with a stock bottom end, many people do it with great results and no issues . I would love to see you build the motor and push that kind of power but you dont need to be built to boost.
Old Jan 1, 2012 | 10:59 PM
shaunrc's Avatar
Oh OK that makes sence I would love to just make 400 and if I can do it safely that would be even better thanks for all the posts and replies
Old Jan 2, 2012 | 08:42 AM
CCTking's Avatar
400 is attainable on the stock bottom but thats right there on the border. Shouldnt have problems but dont be entirely surprised if something does happen. Either way let us know if you actually s/c ur stang and keep us updated! (:
Old Jan 2, 2012 | 09:01 PM
shaunrc's Avatar
So is it possible to use the Eaton supercharger from an 03 04 cobra I have been searching online but haven't found ****
Old Jan 2, 2012 | 09:03 PM
AlsCobra's Avatar
A Man Just Needs Some....
Gonna take a good bit of work. Vortec kit would be easier.
Old Jan 2, 2012 | 09:37 PM
shaunrc's Avatar
That's what I thought but you can find Eaton's online for 400 to 600 so I was thinking the Eaton would be more cost effective
Old Jan 2, 2012 | 10:41 PM
CCTking's Avatar
If you factor in the cost of the other work to fit it youd be mich better off with the vortexh kit
Old Jan 3, 2012 | 03:26 AM
shaunrc's Avatar
Yeah your probably right I just wish money grew on trees plus I think the vorthech s/c looks better
Old Jan 3, 2012 | 05:58 AM
CCTking's Avatar
The power comes on smoother and you get to save your mpg's a bit. The thing about your centrifugals is that they dont make you lose your mpg's as much as a roots or twin screw blower
